Static NAT problem
All,
I have a problem in that I have multiple IP addresses that get redirected to the same internal host.....on the same port.
I can't do:
static (dmz1,outside) x.x.x.x x.x.x.x netmask x.x.x.x
And I can't do:
static (dmz1,outside) tcp x.x.x.x port x.x.x.x port netmask 255.255.255.255
Can I do anything for this?
John
HTH, John *** Please rate all useful posts ***
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Static NAT problem
John
I don't think you can do this with the ASA. If the source addresses were different depending on the public IP address being accessed then you could do something but if this isn't the case i don't think the ASA will let you configure this.
Jon
Vikram
Many thanks for this. I was involved in that post too so i should have remembered :-)
John
Apologies, totally forgot about that post, your memory goes as you get older :-).
Jon
no worries JON, we all make mistakes :).
Jon,
I submitted a tac case yesterday, and they said that it was impossible.
I just tested this on my ASA at the house, and it works great. =)
Thanks Jon and Vikram!
John
119
