Static nat using the outside interface
Just curious, what exactly would happen if i apply a static nat using the outside interface IP pointing to a device behind my inside interface?  I am thinking if the global nat IP is using a different IP than the outside interface then it's ok.  I am accustomed to seeing a global nat IP A and static nat B and an outside interface IP C.  It never crossed my mind to mix it up where my global nat IP is still A but my static nat and outside interface IP is both C.
Thanks in advance.
1 ACCEPTED SOLUTION
Re: Static nat using the outside interface
Marcus,
So long as this outside interface is used for STATIC PAT and not 1-1 NAT you are good. Otherwise all traffic received by the outside interface will be sent to the inside host - meaning you cannot even manage the outside interface using ssh or asdm.
Here is a sample.
Let us say your outside interface IP address is 1.1.1.1
you also have 1.1.1.2 available.
Your static lines can be like this:
static (inside,outside) tcp interface 80 10.10.10.1 80 net 255.255.255.255  -----> static pat for inside webserver 10.10.10.1
static (inside,outside) 1.1.1.2 10.10.10.2 net 255.255.255.255  --------------> 1-1 static nat for inside server 10.10.10.2
Pls. make sure to rate the answers and mark them solved if it solves the issue.
-KS
1 REPLY
Marcus,
Here is a sample.
-KS
302
