Static PAT/ACL help
I have a client that needs access to a particular server on the DMZ from the outside Interface - I have created a static PAT statement 1200 translated to 1200 (I have created the 1200 port so they can access this particular server) and created an access-list from outside to the DMZ. When i run packet tracer it fails at the last part at the NAT.
Type - NAT
Subtype - rpf-check
Action - DROP
Show rule in NAT Rules table.
Config
static (DMZ,Outside) tcp interface 1200 access-list DMZ_nat_static_2
nat-control match tcp DMZ host 2.2.2.2eq 1200
Outside host 80.80.80.80 static translation to 90.90.90.90/1200 translate_hits = 0, untranslate_hits = 11
config;
access-list DMZ extended permit object-group DM_INLINE_PROTOCOL_1 host 2.2.2.2 host 80.80.80.80
access-list DMZ_nat_static_2 extended permit tcp host 2.2.2.2. host eq 1200 host 80.80.80.80
access-list Outside_access_in extended permit tcp host 80.80.80.80 host 2.2.2.2
Not sure if the above access-list/PAT are correct
Re: Static PAT/ACL help
Doesn't look correct.
Can you please advise what is the ip address of the outside interface, and the ip address of the DMZ server?
I will give made up IP
Remote IP:  22.22.22.22
My outside IP: 11.11.11.11
My DMZ Server: 33.33.33.33
OK, base on the following information:
You can configure the following:
static (DMZ,Outside) tcp interface 1200 33.33.33.33 1200 netmask 255.255.255.255
access-list Outside_access_in permit tcp host 22.22.22.22 host 11.11.11.11 eq 1200
I assume you already have the following:
access-group Outside_access_in in interface outside
OR/ alternatively if you need to be very specific that only traffic from 22.22.22.22 needs to be translated, then the following:
access-list DMZ-NAT permit tcp host 33.33.33.33 eq 1200 host 22.22.22.22 eq 1200
static (DMZ,Outside) tcp interface 1200 access-list DMZ-NAT
Thanks, I will give that a bash
I have sent you a PM. Can you have a look please?
243
