Static PAT help
I want people on the outside going to https://1.1.1.68 to be allowed and be redirected to inside address
192.168.168.242
outside interface IP address is 1.1.1.65 255.255.255.240
Here is what I was going to configure, will this accomplish what I want?
object network 1.1.1.68_OWA
 host 1.1.1.68
object network TCP_OWA_242_443
 host 192.168.168.242
 nat (inside,outside) static 1.1.1.68_OWA service tcp https https
access-list outside_inbound extended permit tcp any4 host 192.168.168.242 object-group DM_INLINE_TCP_242_443
Mike
Bronze
that should do it. You don't
that should do it. You don't really need the port translation if you just want to do a one-to-one mapping. so it would look like this:
Thanks for the input and info
Thanks for the input and info. I noticed I had a few things wrong in my first post.
Here are the corrections please let me know if this is still good.
The users will go to https://1.1.1.68:443
and outside interface IP address is 1.1.1.65 255.255.255.240
The reason is I will have need to setup other ports to the same box so I would need the PAT.
Here is the corrected config....I think :-)
 host 1.1.1.68
access-list outside_inbound extended permit tcp any4 host 192.168.168.242 object-group TCP_OWA_242_443
Bronze
When I first looked at it I
When I first looked at it I thought DM_INLINE_TCP_242_443 was a protocol group you had defined somewhere else but not included in the snippet.
From your revision it looks like you're calling the network group where the port # or service group should be. I think what you're looking for is something like this:
 host 1.1.1.68
access-list outside_inbound extended permit tcp any object TCP_OWA_242_443 eq https
Yeah the DM_INLINE was a
Yeah the DM_INLINE was a mistake.
Thanks for the correction, and for your help. I will be trying this and will post results
Mike
37
