Static PAT issue with 8.4
I have a simple small network setup here, and trying to setup a simple Static PAT on HTTPS, for some reason the NAT rule is dropping the packet.  Here is the setup.
Internal Subnet: 172.31.0.0/24
External Internet DHCP
Host object: 172.31.0.13
There is also a SSL anyconnect VPN setup but is using port 444.
object network obj_any-01
nat (inside,outside) dynamic interface
object network LD-App01
nat (inside,outside) static interface service tcp https https
nat (inside,any) after-auto source static obj-172.31.0.0 obj-172.31.0.0 destination static Personal-VPN Personal-VPN no-proxy-arp
object network obj-172.31.0.0
subnet 172.31.0.0 255.255.255.0
object network Personal-VPN
subnet 172.31.1.0 255.255.255.0
subnet 0.0.0.0 0.0.0.0
host 172.31.0.13
access-list inside_access_in extended permit ip any any
access-list inside_nat0_outbound extended permit ip 172.31.0.0 255.255.255.0 object Personal-VPN
access-list Personal-VPN-ACL standard permit 172.31.0.0 255.255.255.0
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit tcp any object LD-App01 eq https
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
Here is the packet trace
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   172.31.0.0      255.255.255.0   inside
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Please Help...
Lee
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hello Lee,
The configuaration looks good to me, I would make the following:
object network outside_interface_ip
host x.x.x.x.x
object service https
service tcp source eq 443
no  nat (inside,outside) static interface service tcp https https
nat (inside,outside) 1 source static LD-App01 outside_interface_ip service https   https
Give it a try and let me know regards,
Julio
Do rate helpful posts!
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Hello Lee,
host x.x.x.x.x
Julio
Re: Static PAT issue with 8.4
Tried your recomendation but ran into a error.
I created the object outside_int_ip with the outside ip.
Then tried to create the nat as you have listed but got the following error.
nat (inside,outside)1 source static LD-App01 outside_int_ip service https https
ERROR: % Invalid input detected at '^' marker.
LD-FW01(config-network-object)# nat (inside,outside) 1 source static LD-App01 $
ERROR: Address 75.188.84.144 overlaps with outside interface address.
ERROR: NAT Policy is not downloaded
Lee
Hello Lee,
It should not have failed!
You placed the object right, not the Ip?
Here is the current object list and the nat command with the failure message.  I'm also running the current 8.4(3)
LD-FW01# show run ob
host 172.31.0.13
description Spiceworks
service tcp source eq https
object network outside_int_ip
host 76.188.84.144
LD-FW01# con t
LD-FW01(config)# object network LD-App01
You need to do it outside the object network that is the problem!
So just by being on config te add the nat command  I gave you
still getting the same error.
LD-FW01(config)# nat (inside,outside) 1 source static LD-App01 outside_int_ip $
For Julio and anyone else who may read this.  The origional config I posted worked just fine though for some reason the NAT in the packet trace still shows as being dropped.  The actual issue is that the server I was Natting to closed the 443 (https) port for some reason.  As soon as I fixed the port issue on the server, I was able to NAT correctly through the ASA.
Lee
Hello Lee,
Glad to hear everything is working now.
Just in case the one option I gave you should be like this
nat (inside,outside) 1 source static LD-App01 interface service https   https
Julio
1543
