Still need help:Pix515E Hairpin access to inter-Lan error:%PIX-session-3-305006
Hi, Everyone,
Our Pix515E, OS 8.0.4, has been working for long time, recently we need  configure a  new VLAN for accounting group, PCs hooked to this VLAN must have full access to our existing internal LAN, I have  scratched my head for serveral days to get it work, so far no luck.  PCs of VLAN can get outside (Internet), but no way they can access inside systems. Pix logged error 305006 ( or 305005) of  something like:
Sep  2 12:35:09 pix515e :Sep 02 12:37:46 EDT: %PIX-session-3-305006: p
ortmap translation creation failed for udp src vlan10:192.168.100.100/54310 dst inside:10.1.1.7/53
Sep  2 12:21:49 pix515e :Sep 02 12:24:27 EDT: %PIX-session-3-305005: N
o translation group found for udp src vlan10:192.168.100.100/51015 dst inside:10.1.1.7/53
I  have  tried " crypt ikekmp nat-traversal"  No LUCK;  I have tried all kinds of  access-rules no luck...   I  really don't understand why the inter-lan traffic is not allowed...
My shorted version of  config is listed in the following:  we have DMZ too, but unrelated here, becuase all I want know is  allow traffic from VLAN-->INSIDE  to happen.  Any suggestions are  greatly  appreciated.
PIX Version 8.0(4)
hostname pix515E
interface Ethernet0
nameif outside
security-level 0
ip address 71.X.X.X 255.255.255.0
ospf cost 10
interface Ethernet1
nameif inside
security-level 100
ip address 10.1.1.254 255.255.0.0
ospf cost 10
interface Ethernet1.10
description Vlan on inside
vlan 10
nameif vlan10
security-level 100
ip address 192.168.100.1 255.255.255.0
ospf cost 10
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_access_in extended permit icmp pix-inside 255.255.0.0 any echo
access-list inside_access_in extended permit udp pix-inside 255.255.0.0 any object-group ntp-udp
access-list inside_access_in extended permit tcp pix-inside 255.255.0.0 any eq domain
access-list inside_access_in extended permit tcp host et2 any eq smtp
access-list inside_access_in extended permit udp host new-cis-router any
access-list vlan10_access_in extended permit ip any any
arp timeout 14400
nat-control
global (outside) 10 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 10 10.1.1.0 255.255.255.0
nat (inside) 10 10.1.2.0 255.255.255.0
nat (inside) 10 10.1.0.0 255.255.0.0
nat (vlan10) 10 192.168.100.0 255.255.255.0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 71.X.X.X 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map outside_dyn_map 60 match address outside_cryptomap_dyn_60
crypto dynamic-map outside_dyn_map 60 set transform-set ESP-3DES-MD5 ESP-3DES-SHA ESP-DES-MD5 ESP-DES-SHA
crypto dynamic-map outside_dyn_map 60 set security-association lifetime seconds 28800
crypto dynamic-map outside_dyn_map 60 set security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime seconds 28800
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime kilobytes 4608000
crypto map outside_map 65534 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp identity hostname
crypto isakmp enable outside
crypto isakmp policy 20
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
threat-detection basic-threat
group-policy cnf-vpn-cls internal
group-policy cnf-vpn-cls attributes
wins-server value 10.1.1.7
dns-server value 10.1.1.7 10.1.1.205
vpn-tunnel-protocol IPSec l2tp-ipsec
default-domain value *.com
tunnel-group cnf-vpn-cls type remote-access
tunnel-group cnf-vpn-cls general-attributes
address-pool cnf-8-ip
isakmp ikev1-user-authentication none
tunnel-group cnf-vpn-cls ppp-attributes
authentication ms-chap-v2
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum 768
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect http
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
1 ACCEPTED SOLUTION
Re: Pix515E Hairpin access to inter-Lan error:%PIX-session-3-305
You have same security.
vlan 10
nameif vlan10
security-level 100 --------------------------------------> change that to a 90
ospf cost 10
change the security level to a 90
or add
static (vlan10,inside) 192.168.100.0 192.168.100.1 net 255.255.255.0
-KS
You need static translation from inside to vlan.
static (inside,vlan10) 10.1.0.0 10.1.0.0 net 255.255.0.0
That should take care of it.
-KS
Thank you KS, I really appreciate your help.
I run the configuration you suggested, but unfortunately it did not make any difference, the log still shows error 305006:
Sep  2 15:56:28 pix515e :Sep 02 15:59:06 EDT: %PIX-session-3-305006: portmap translation creation failed for icmp src vlan10:192.168.100.100 dst inside:10.1.1.7 (type 8, code 0)
(the configuration command is accepted, I ran under the PIX console, I can view it by ADSM).
thanks.
vlan 10
nameif vlan10
ospf cost 10
or add
-KS
I typed it incorrectly.
Last octet was a .1 instead it should be a 0
static (vlan10,inside) 192.168.100.0 192.168.100.0 net 255.255.255.0
-KS
Once again, thank you very much for the help.  Unfortunately these changes did not work, the same 305006 error.
I know this is really hard, I got another system guy tried  for  4 days  plus countless hours from myself did not make it work
This is strange.
You are seeing both these messages?
The above two are diff. One is
port map translation creation failed  ------> means the global line is the problem
the other is
no translation group found  -----> this means the nat line is the problem.
pls. post the output of
sh nameif
sh ip
sh arp | i vlan10
-KS
Thank you very much, kusankar.
Great news, it  actually works now !!! ( I was off Last Friday becuase of  EARL and Monday too).
when I came to work this morning, it still did not work, but the log message shows this way:
Sep  7 10:25:33 pix515E:Sep 07 10:28:18 EDT: %PIX-session-3-106014: Deny inbound icmp src vlan10:192.168.100.100 dst inside:10.1.1.7 (type 8, code 0
Then I  remember I changed  VLAN10 security level from 100-->90 and I checked this box (on ADSM): "Enable traffic between 2 or more interfaces which are configured with same security levels",  so when I changed back  VLAN10 security from 90--->100, traffic from VLAN10 -->inside is working perfectly.
Now I have  a  slightly different configuration (actually this was the original problem, I build  a new VLAN for testing first and I thought the problems are the same): our accounting dept IT guy wants his own control of  a  cisco ROUTER, he got 3  VLANs already, for this PIX515E, he built a  VLAN8 with IP 10.8.1.0/24, he routes all VLAN8  traffic to another router connected to PIX directly (10.1.2.222), his  VLAN8 can  go outside (internet) , but not inside, log is almost identical:
Sep  7 11:23:03 pix515e:Sep 07 11:25:50 EDT: %PIX-session-3-305006: portmap translation creation failed for udp src inside:10.1.1.7/53 dst inside:10.8.1.103/51196 (type 0, code 0)
*****Note:  I ping from 10.8.1.103 XP PC but this log shows the coming-back-way failed*****
( config related to inside8)
#name 10.8.1.0 inside8 description routed-inside-network
#access-list inside_access_in extended permit ip inside8 255.255.255.0 any
#nat (inside) 10 inside8 255.255.255.0
#route inside inside8 255.255.255.0 10.1.2.222 1
when I try to do the same thing as  you suggested above, PIX does not allow me:
pix515E(config)# static (inside,inside8) pix-inside pix-inside netmask 255.255.0.0
ERROR: % Invalid input detected at '^' marker.
I work here as ORACLE DBA , we don't have complex networking here so Cisco stuff is kind of my side job,  please  excuse me for not being able to really grasp what you did actually made the difference regarding error 305006. I know  I'm too dumb I can't fix the same error with some different configuration.
Once again,  I really appreciate your tremendous help.
I know  I might better start  a new discussion becuase the problem is somewhat different, but the messages are the same 305006, just this time the  traffic is  routed to PIX from another VLAN, the destination is still U-turn access to inside LAN.   Any suggestions and  advises are  greatly appreciated.
----copied from previous posting
898
