Strange CLI issue
When I do a 'show run' command it scrolls all the way through the whole thing without page breaks. I have quite a long config so this is an issue because I can't see what is at the beginning of the config. It happens if I telnet or SSH and with different programs. Anyone know how to correct this?
*EDIT*
It's not just 'sh run'. It happens with anything I display with the show command.
1 ACCEPTED SOLUTION
Bronze
Re: Strange CLI issue
Sorry I assumed you were using a switch/router firewall. Please try pager 30 from the config mode:
ASA5510-FW1(config)# pager 30
regards
Bronze
you might have term length set to zero in your configuration. Try to set term length to a specific number such as
term len 30
regards,
I don't see a way to set term length, only term width.
Bronze
regards
Sorry, I probably should have clarified I was using an ASA 5510. Your solution worked, thank you.
Bronze
I am glad I was able to help out and thanks much for rating the post. We all learn from this forum and it is great when folks rate helpful posting.
115
