Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Strange issue on newly installed 5510
Hi all,
A couple issues came up after installing our new 5510, a couple sites that uses the same ISP as our's had issues, one where we can email them but their incoming to us wasn't working, and another site we couldn't browse on the web.
This all worked after putting back the old firewall. I was wondering and it might be a dns issue with our isp's and the asa could be blocking on the outside int, on the old firewall I have the trust to untrust allow dns outgoing, that setting is not on the asa since it's inside int has 100 rule. I also talked to the IT dept of the site that had incoming email issues, he said 2 of their Exchange servers are connected to the same isp as ours, most sites worked and email, but there might be more we just haven't tried yet. For now I have our old firewall till I figure out what's causing some sites to not work on the asa.
update - I added my object group DNS-SERVERS on the outside int, I'll test again to see if the sites in question works
here's my latest config, thanks in advanced.
crxasa# sh run
: Saved
ASA Version 9.1(2)8
hostname crxasa
domain-name cirexx.com
enable password 5wq4IltsegGVfI30 encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 12.x.x.34 255.0.0.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 208.x.x.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 15
boot system disk0:/asa912-8-k8.bin
ftp mode passive
clock timezone PST -8
clock summer-time PDT recurring
dns domain-lookup inside
dns server-group DefaultDNS
name-server 208.x.x.12
domain-name domain.com
same-security-traffic permit intra-interface
object network obj-LAN
subnet 0.0.0.0 0.0.0.0
object network cirexxintldc
host 208.x.x.12
object network sharks
host 208.x.x.5
host 208.x.x.85
object network crxmail
host 208.x.x.3
object network svr-sales
host 208.x.x.94
object network randy
host 208.x.x.84
object network jana
host 208.x.x.133
object network carlo
host 208.x.x.30
object network LAN
subnet 208.x.x.0 255.255.255.0
object network MB1
host 12.x.x.35
object network MAIL
host 12.x.x.43
object network cirexxmas90
host 208.x.x.122
object network cirexxintl2
host 208.x.x.85
object network bacon
host 208.x.x.83
object-group service TCP tcp
description domain,http,smtp services
port-object eq www
port-object eq https
port-object eq domain
port-object eq smtp
port-object eq pop3
object-group service WEBSERVER tcp
description ftp,http,https services
port-object eq www
port-object eq ftp
port-object eq ftp-data
object-group network MAILSERVERS
network-object host 208.x.x.12
network-object host 208.x.x.3
object-group network DNS-SERVERS
network-object host 208.x.x.5
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group network REMOTEUSERS
network-object host 208.x.x.133
network-object host 208.x.x.84
network-object host 208.x.x.30
access-list ACL_OUT extended permit tcp any host 208.x.x.85 object-group WEBSERVER
access-list ACL_OUT extended permit tcp any host 208.x.x.94 eq 3389
access-list ACL_OUT extended permit tcp any object-group MAILSERVERS object-group TCP
access-list ACL_OUT extended permit icmp any any echo-reply
access-list ACL_OUT extended permit icmp any any unreachable
access-list ACL_OUT extended permit icmp any any time-exceeded
access-list ACL_OUT extended permit tcp object-group MAILSERVERS object-group TCP any
access-list ACL_OUT extended permit tcp any object-group REMOTEUSERS eq 3389
access-list ACL_OUT extended permit tcp any host 208.x.x.122 eq 3389
access-list ACL_OUT extended permit tcp any host 208.x.x.85 eq 51000
access-list ACL_OUT extended permit tcp any host 208.x.x.83 eq 6272
access-list ACL_OUT extended permit tcp any host 208.x.x.83 eq www
access-list ACL_OUT extended permit tcp any object-group DNS-SERVERS eq domain
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-714.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,inside) source dynamic LAN interface destination static MB1 cirexxintldc
nat (inside,inside) source dynamic LAN interface destination static MAIL crxmail
nat (inside,outside) dynamic interface
nat (inside,outside) static 12.x.x.35
nat (inside,outside) static 12.x.x.37
nat (inside,outside) static 12.x.x.36
nat (inside,outside) static 12.x.x.43
nat (inside,outside) static 12.x.x.49
nat (inside,outside) static 12.x.x.54
object network jana
nat (inside,outside) static 12.x.x.44
nat (inside,outside) static 12.x.x.53
nat (inside,outside) static 12.x.x.40
nat (inside,outside) static 12.x.x.38
nat (inside,outside) static 12.x.x.41
access-group ACL_OUT in interface outside
route outside 0.0.0.0 0.0.0.0 12.x.x.33 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 management
ssh timeout 30
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 30
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
username admin password zULPhOeRwWoy3VJE encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect ip-options
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:bd0acd7effe0144b539caefb6c517e30
: end
crxasa#
Message was edited by: CARLO DOMINGUEZ
Re:Strange issue on newly installed 5510
Hello Carlo,
So u can email but u do not receive them.
Can U provide us
Packet-tracer input outside 4.2.2.2 1025 x.x.x.x eq 25
Where x.x.x.x is the public ip address of the SMTP server.
Sent from Cisco Technical Support Android App
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
   Hi Julio, thanks for the reply, after digging around I found out that I had the wrong subnet mask for our outside ip, when I configured the outside int I didn't manually enter the correct mask, the asa automatically put a /8 on it which gave the wrong ip range that the isp leased us.
   After looking at our old firewall it had a /27, I had thought it was a dns issue at first, but I just overlooked the ip config, after setting it to /27 things started to flow like normal again.
Hello Carlo,
Glad to hear that is up and running
Please mark the question as answered so future users can learn from this
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Hi Julio, actually I think I'm not out of the woods yet, one of my users say a customer can't send us email, we can send to them fine, I see it go out on the exchange console queue, but incoming somehow it just goes to nowhere, there's no logs indicating an error or an NDR to the sender, they wanted to put back the old firewall, but most of our emails in and out are ok, just one customer, I test for a ptr record and some of the free dns tools come out ok, there's one place that says our ptr fails but it's one place. I'm stumped, it all seems to happen after the new firewall.
update - looks like it's back to normal again after I redid my dns acl, I added a group object for dns tcp-udp instead of just tcp, mail seems to flow again.
168
