Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Strange VPN Remote Issue
we have configured IPSEC Remote VPN on ASA 5510. Remote client is able to successfully authenticate and establish a tunnel , however user will not be able to ping any inside Hosts . As troubleshooting measure , i did enable ICMp trace 255 , i see the VPN Client ICMP request and a echo reply back from the Inside host hitting the Inside Interface of the Firewall . Can you please go through the configuration and let me know if anything needs to be changed .
Path the User will take is
VPn Usr-->Firewall ( inside ip 10.10.10.2)->L3switch (10.10.10.1)->Host (10.10.10.5)
Community Member
Re: Strange VPN Remote Issue
Missed the attachment last time
Does anything else seem to work other than icmp?
Try:
same-security-traffic permit intra-interface
HTH,
John
HTH, John *** Please rate all useful posts ***
Community Member
Thanks for responding back John , modified the Configuration as per your suggestion , but no LUCK . No Traffic is being received back by the Remote client . Looks like the Return/response packet sent by the Inside host to the remote client is reaching the ASA but is not entering the IPSEC tunnel ..
Debug ICMp Trace output
echo reply from inside:10.10.11.1 to outside:192.168.14.1 ID=1 seq=758 len2
ICMP echo request from outside:192.168.14.1 to inside:10.10.11.1 ID=1 seq=759 l2
ICMP echo reply from inside:10.10.11.1 to outside:192.168.14.1 ID=1 seq=759 len2
ICMP echo request from outside:192.168.14.1 to inside:10.10.11.1 ID=1 seq=760 l2
ICMP echo reply from inside:10.10.11.1 to outside:192.168.14.1 ID=1 seq=760 len2
ICMP echo request from outside:192.168.14.1 to inside:10.10.11.1 ID=1 seq=761 l2
ICMP echo reply from inside:10.10.11.1 to outside:192.168.14.1 ID=1 seq=761 len
Are you trying to ping from 192.168.14.0 or are you trying to ping TO 192.168.14.0? Try adding "inspect icmp" to your default policy.
HTH,
John
Community Member
Hi John ,
192.168.14.1 is the remote Client Ip assigned by ASA Ip pool .10.10.10.1 is the L3 Switch interface behind the Firewall .
I am trying to ping from 192.168.14.1 (remote vpn Client) ---> 10.10.10.1 (L3 Switch ).
Can you ping the .14.1 address from the ASA?
Do you have a route in your L3 switch back to the 192.168.14.0 subnet?
Community Member
Hi John ,
Yes L3 has a defualt route pointing to ASA .
I think If routing was an issue we would not received the reply packets back from the host when we did the Debug ICMP Trace on the ASA , Your thoughts on this ?
Also i am not able to Ping the Remote Client (192.168.14.1) from the ASA
You should at least be able to hit it from the ASA. What do you get back if you do a:
sh vpn-sessiondb remote
Community Member
First of all , i have no words to Thank you !!
You are correct ,Ideally we should be able to ping the Remote Client from the ASA Atleast . I think that 10.10.0.0 is not going into the ipsec tunnel when the destination iip is 192.168.14.0 for some reason ..Anywasy , below is the remote Db Output
Session Type: IPsec
Username : Administrator Index : 2
Assigned IP : 192.168.14.1 Public IP : X.X.12.200
Protocol : IKE IPsec
License : IPsec
Encryption : 3DES Hashing : SHA1
Bytes Tx : 1828 Bytes Rx : 8518
Group Policy : tom Tunnel Group : tom
Login Time : 20:53:45 UTC Mon May 11 2009
Duration : 0h:00m:34s
NAC Result : Unknown
VLAN Mapping : N/A VLAN : none
Glad to help :) What are they using to connect with? Cisco's VPN client? Is the stateful firewall on by chance?
And let me get this right, you've always tried to ping from this side to the 192.168.14.0 side, or have you tried 192.168.14.1 -> 10.x.x.x?
Community Member
yes i have tried both directions ..
192.168.14.0 (remote client) ---> 10.x.x.x (host behind firewall_
10.x.x.x (host behind firewall)--> Remote client . No Traffic at all .
Yes , Remote USers connect using Cisco VPN Client 5.03XX version
No , Stateful firewall is OFF .
Do you get an entry in your routing table for that host? What shows as it's next hop?
Try this:
access-list VPN permit host 0.0.0.0
group-policy tom attrib
split-tunnel-specified excludespecified
split-tunnel-network-list value VPN
John
Community Member
I tried that too , but no Luck . So i went ahead and opened a Case with TAC ,I will keep you posted on it ..But again thanks a ton for helping me on this issue , if you ever visit Atlanta ,Beer is on me .
Community Member
Can u try specific networks rather then using "any" in your nat0 acl?
Community Member
Thanks for taking time to go through my Issue nomair . I modified the ip's but that did not make any differance
335
