Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
STUN and SIP for Hearing Impaired Video Phone
I have ZVRS Z-340 I am trying to connect to an outside server. I have the policy outbound for the ports the phone needs. If SIP is inspected on the ASA is their anything else I need to enable for STUN?
Below are the ports the Vid phone requires outbound only. I guess my question is do I need to config more than access rules for the STUN ports. The SIP port is set.
80 TCP 443TCP
3478 UDP STUN
3479 UDP STUN
5060 UDP SIP
5200 UDP
23000-23003 UDP
1 REPLY
Silver
Re: STUN and SIP for Hearing Impaired Video Phone
When a user sends a message to a server from inside a NAT, the server will reflect back whatever address the NAT gives it. STUN allows this reflected address to be used to establish an RTP session with the user inside the NAT, without involving any of the SIP proxies in the middle.
271
