Sub Interface on Cisco ASA 5505
Hi Experts, Can we make sub interface on Cisco ASA 5505 model and if its possible then do that interface need to be upgraded into Trunk Port. Pls explain briefly. Thanks
Re: Sub Interface on Cisco ASA 5505
No - it's not possible, with a basic license, you need a Security Plus license.
HTH>
Yes, we have Security Plus License installed.
the just create a sub interface on the physical interface that connects to a trunk port:-
interface ethernet 1.1
vlan <>
HTH>
Can you explain briefly and give an example, if possible. Thanks
See my previous post - explanation & example already provided.
Model Guidelines
Subinterfaces are not available for the ASA 5505 ASA
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/intrface.html
Mike
Mike
I have been working on a configuration in which I wanted to do subinterfaces as well.  I found that you can not create them even with having a security plus license.
Keith
Super Bronze
To my understanding you only configure Vlan interfaces on the ASA5505 just like a L3 Switch.
For example
interface Vlan10
nameif LAN
security-level 100
ip add 10.10.10.1 255.255.255.0
interface Ethernet0/1
switcport access vlan 10
Then you either make physical ports on the ASA5505 as Access Mode ports on that Vlan ID or configure a physical interface as a Trunk
Configuring the Trunk will require the Security Plus License.
- Jouni
Sub interfaces are available
Sub interfaces are available on all ASA models and Next Gen Models EXCEPT the ASA 5505.
Cisco ASA 5500 - Sub Interfaces and VLANS
Pete
10267
