Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Subinterfaces configured but hosts are not able to connect
I configured 3 LAN interfaces on ASA. 2 interfaces are able to communicate to each other but at 3rd interface I am creating subinterfaces. also I can ping hosts on other VLANs from Cisco 2960. but host-host communication is not getting possible.Please suggest the solution for this
2 ACCEPTED SOLUTIONS
Re: Subinterfaces configured but hosts are not able to connect
For communication between interfaces, you would need to configure static NAT to itself statements:
For example: If you are trying to communicate between INSIDE-VL5 and INSIDE-VL17 subnets:
static (INSIDE-VL5,INSIDE-VL17) 192.168.5.0 192.168.5.0 netmask 255.255.255.0
Then "clear xlate" after the above changes.
Same goes for communication to other subinterface.
Hope that helps.
Hall of Fame Super Blue
Don't forget you will need statics both ways eg.
vlan 5 = 192.168.5.0/24
vlan 17 = 192.168.6.0/24
static (VLAN5, VLAN 17) 192.168.5.0 192.168.5.0 netmask 255.255.255.0
static (VLAN17, VLAN5) 192.168.6.0 192.168.6.0 netmask 255.255.255.0
Jon
Hope that helps.
Community Member
Thanks for the reply, but How I wil make a static NAT with the one which is already created.
for example: if Static NAT is created between VLAN-15 and VLAN-21 then How I can make one static statement with VLAN-15 to VLAN-5 ?
Will it work or is there another way to configure it?
It will work fine, you can have multiple static NATs eg.
static (INSIDE-VL5,INSIDE-VL21) 192.168.5.0 192.168.5.0 netmask 255.255.255.0
etc..
Jon
Community Member
Thanks, It worked but still I can not ping to host connected to interface e0/3.1 from the host connected to e 0/1. but vice versa is possible
Jon
Community Member
It worked for me.
284
