08-03-2007 08:28 AM - edited 03-11-2019 03:53 AM
I am going to purchase a Cisco ASA5510. What what is the recommeded training course for configuring the ASA for firewall? It looked like the SNPA focused quite a bit on VPN
Solved! Go to Solution.
08-03-2007 10:59 AM
I took the former PIX exam (6.3) version a couple years ago. I'm currently studying for ccie sec. lab and using the 7.2(2) Config Guide as one of my sources.
08-03-2007 10:12 AM
you're going to get a lot of vpn coverage with any asa course/text that you pick up.
I say download the pdf manual from CCO.
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/index.htm
08-03-2007 10:20 AM
Ok, Thank you!
08-03-2007 10:22 AM
Did you take any formal training or did you just read the user guide? Also, are you just using yours as a firewall only?
08-03-2007 10:59 AM
08-03-2007 11:01 AM
OK, thanks. I was wondering if you had taken the SNPA course for the ASA5500.
