Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
SW-6509-FWSM failover Troubleshooting First aid
Fault Description:
(1)
active  FWSM and standby FWSM  inside interface Between,ping fails。
on side FWSM---active: ping 172.17.1.50 -------OK,ping 172.17.1.49------ping fails;
on side FWSM---standby: ping 172.17.1.49--------OK,ping 172.17.1.50-------ping fails;
but,active  FWSM and standby FWSM  outside interface between,ping OK。
on side FWSM---active:ping 172.17.1.36  、  ping 172.17.1.37、ping 172.17.1.35/33/34/、ping www.baidu.com -----------All OK;
on side FWSM---standby:ping 172.17.1.36 、  ping 172.17.1.37 、ping 172.17.1.35/33/34/、ping www.baidu.com-----------All OK;
(2)
Another problem:
active  FWSM and standby FWSM  inside interface,ping  7706-------All fails。
Summary:May be caused fwsm。
Topology :Attachment
FWSM :
FWSM#                       show failover state
====My State===
Primary | Active |
====Other State===
Secondary | Standby |
====Configuration State===
    Interface config Syncing - STANDBY
    Sync Done
====Communication State===
    Mac set
=========Failed Reason==============
My Fail Reason:
    Ifc Failure
Other Fail Reason:
    Comm Failure
FWSM# show failover
Failover On
Failover unit Primary
Failover LAN Interface: lan Vlan 997 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 15 seconds
Interface Policy 50%
Monitored Interfaces 42 of 250 maximum
Config sync: active
Version: Ours 4.0(13), Mate 4.0(13)
Last Failover at: 19:08:24 Beijing Dec 2 2013
    This host: Primary - Active
        Active time: 358944 (sec)
    Interface outside (172.17.1.36): Normal
    Interface inside (172.17.1.49): Normal (Not-Monitored)
    Other host: Secondary - Standby Ready
        Active time: 0 (sec)
    Interface outside (172.17.1.37): Normal
    Interface inside (172.17.1.50): Normal (Not-Monitored)
(Not-Monitored) -----------------??????
Everyone's tags (6)
249
