syslog issue
raj_bjs77
I have enabled syslog setting on my ASA 7.2
logging enable
logging trap alerts
logging host inside x.x.x.x tcp/1468
logging facility 20
Whenever i enter logging facility 20 my syslog server starts receiving logs but stops after 15-20 min.
Also logging facility 20 does not appear in my running config.
Again if i enter the same command it starts working but again stops after 15 min.
Any suggestion..
drolemc
Level 6
Level 6
I think you are facing the problem since you are using TCP because the connection having to be re-established and if you have a lot of Syslog messages this will definaitely be a problem. You can use UDP instead of TCP for sending syslog messages. Following link may help you
http://www.cisco.com/en/US/docs/security/asa/asa71/system/message/logconf.html
