syslogs with from VoIP traffic
We have a CUBE Router 3845 and a Callmanager doing SIP with a ASA 5520 inbetween.
On the ASA, I keep seeing large amount of syslogs regarding invalid UDP fields (See attached screenshot) occur in bursts at a very fast rate.
Is this due to a problem or normal? We ar enot experiencing any VoIP issues other than a bug with SIP inspection. Basically SIP inspection wasn't doing it's job so I have to manually enter rules and NAT statements in to help the traffic from the CUBE router to the call manager.
In the PIC, I scrubbed out addresses, but the source IP is always the CUBE router and destination is the Call Manager.
Dave
1 REPLY
Re: syslogs with from VoIP traffic
The syslog messages are generated on the ASA firewall because the destination port for your UDP traffic is 0 which is not normal:
http://www.cisco.com/en/US/docs/security/asa/asa80/system/message/logmsgs.html#wp4773952
You might want to check why CUBE router is sending traffic towards the Call Manager using UDP port 0.
Hope that helps.
113
