Tcp Connection timeout on ASA for vpn traffic
Hello All
I need an answer please.
I wanted to give tcp conenction timeout as unlimited for some IPs coming through VPN.
So, I created an access-list defining the traffic for which I want this tcp timeout.
Then a class map, policy map, entered set timeout to '0'
Applied it under default service-policy, which is applied as global (by default).
My doubt is should I apply the service policy on the interface or the global will work.
Just a silly doubt
Thanks in advance.
1 ACCEPTED SOLUTION
Super Bronze
I think it should work just fine if you attach it to the default "policy-map" configuration that you have attached globally on the ASA.
You might want to configure the timeout value as something long rather than setting it as unlimited.
- Jouni
Super Bronze
- Jouni
Yes Jouni, its attached under the default policy-map. And as you have suggested, I have changed the timeout value to few hours.
Thank You again
Abhishek
225
