Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
TCP/UDP connection High
We have Cisco ASA 5520.Nowadays we are getting one problem that is TCP/UDP connection fluctuating continuously.
I am checking in ASDM, suppose now showing total no. of connection 50 within 2 sec it's reaching 3000 and again come back to normal.
It's happening continuously.
What might be the reason for that? Pls assist too resolve this issue.
Thanx,
somnath
Re: TCP/UDP connection High
probably you have worms...
try to find suspicious connections
"sh conn"
[Pls RATE if HELPS]
Silver
Can you put sniffer and check which host or application does that?
Dharmesh Purohit
If the connection spikes up to 3000 and then drops sharply 30 seconds later, that is most likely a flood of TCP connection (DoS Attack) that result in short lived, half-open TCP conns. Please gather SYSLOGs during the spikes and provide a sample for us to take a look at.
288
