Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Telnet issue
Hi all,
I my trying to do a telnet but Im always getting timeout. when I check in the pix 515 i see this :
TCP inside 10.100.1.30:55139 inside 142.100.64.11:23, idle 0:00:01, bytes 0, flags SaAB
And I have the same issue with http. Ping works with no proble.
Thanks all.
Hi,This flag shows that the
This flag shows that the TCP Handshake is not yet complete.
Can you share the relevant configuration from the PIX.
Thanks and Regards,
Vibhor Amrodia
Community Member
your session state is not
your session state is not completing .  ping is icmp and does not have a complete 3 way handshake like tcp protocol. (also if timeout happens this means that whole tcp protocol 23 process is not completing within a protocol defined time frame )
test your ping with fix up icmp as well and let us know .
47
