Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Timestamps for logging
i have enabled logging & configured clock time zone and set clock maually in pix525 firewall, but when i issue sh logging command logs are not showing the timestamps.
please find the commands in my firewall:
logging on
logging timestamp
logging buffered notifications
logging trap warnings
logging facility 4
One more thing is after restarting the Firewall clock settings are getting reset.same thing is happening for switches & Router also, but logs are showing timestamp in router & switch.
can anybody help me.
Community Member
Re: Timestamps for logging
can anybody help me on this?
after restarting the router & switch time settings are getting changed.
I am using this command in router & switch
service timestamp datetime localtime.
But in case of firewall timestamp is not showing at all. and after restarting the firewall clock timezone IST 5 30 getting removed.
Router, Firewall, and Switch doesn't have a CMOS battery (like the one in your PC) to keep the time running in the event that the device is restarted or power down. To keep the time, you need an NTP server for your network equipment to sync their time.
