Tracert results always showns same IP on ASA
ktwaddell
I have a ASA 5505 as a default gateway to a network, whenever I tracert to outside it shows every hop ip address as the ip address I'm trying to get too, quick example
lets say I'm in a 192.168.0.0/25 network but I want to trace to 10.10.10.10
tracert 10.10.10.10
1 4ms   5ms   6ms  10.10.10.10
2 7ms 8ms 9ms 10.10.10.10
3 *
4*
5*
6 20MS 20MS 20ms 10.10.10.10
get me?
any ideas on why the asa is doing it?
Kev
7 Replies 7
I have never seeing such a behavior. I would try to enable icmp error inspection and maybe decrement ttl
ok great I'll look that up and give it try tomorrow
Cheers
Kev
Hi Kev,
For Outbound traceroute to work through ASA , folllowing needs to be configured :
policy-map global_policy
class inspection_default
    inspect icmp
    inspect icmp error
access-list out  extended permit icmp any any time-exceeded
access-list out  extended permit icmp any any unreachable
access-group out in interface outside
If you want to see ASA as a hop in the traceroute output :
ciscoasa(config)#policy-map global_policy
ciscoasa(config-pmap)#class class-default
ciscoasa(config-pmap-c)#set connection decrement-ttl
ciscoasa(config)#icmp unreachable rate-limit 10 burst-size 5
Ankur
Hiya
That didn't work sadly, I got less replys but they were still all showing as the IP address I want to get too. I've just checked checked and I get the very same thing on my other ASA as well.
ok why can I insert, an image, video, url but not the config!!
how do I put a config on here??
too early for this
Hi Kev,
Is the ASA running an 8.3 or 8.4 version of software? If so, this is caused by the following bug:
CSCtj50797 - Traceroute to or through ASA always shows destination IP
The bug is fixed in 8.3.2 and 8.4.1 and higher.
-Mike
Morning All
Well that is spot the issue I'm having, i have 3 ASA's 2 with the same issue and 1 working fine, ios below
not working correctly
5505 8.4(2)
5510 8.4(1)
working fine
5510 8.2(1)
Cheers
Kev
DaveNoonan26775
I know this is ancient but it shows up in search results.
Someone else on CCO said that the issue was a no-nat statement with Any as the source interface.  I have inside-outside in my no-nat and am seeing this problem.  I do have Any in the default NAT statement and will try changing that later.
