You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Traffic Analysis - ASA
Hi all,
If I noticed a lot of (incoming&outcoming) traffic in outside interface of ASA. Is there any way to know where is this traffic coming or going to (IP address)?
And if that traffic happened earlier (for example 1 day ago), can I still know the origin or destination IP address?
Please help!!
Thanks in Advance,
Omer
  • Firewalling
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
The open source tool for capturing and analyzing netflow exports is ntop. Please see more information at http://www.ntop.org/products/ntop/
There's no easy way to tell if you didn't already have instrumentation turned on.
The ASA is capable of exporting netflow data to an external collector. It is there that you would be able to retrospectively analyze top flows by source and destination address and port. Additionally in near real time you can monitor the top 10 hosts in the ASDM dashboard (or CLI equivalent).
Thanks Marvin for your reply.
Actually I asked this question because I've seen spiky load in my outside interface which looked suspicious. I was curious to know where it came from.
I used show conn command, but it was only showing the connections in use.
I'm using opennms as monitioring tool, but not sure if it will help in this case.
Any recommendation??
Omer
Thanks for the valuable information
1242
