Traffic Flow from ASA to Server
Hi Everyone,
I need to add ASA to CSM Server.
ASA need to talk on port 443 with CSM server.
Here is setup
ASA1---------lan network--------ASA2---------Interface Z  is connected to CSM server.
CSM server IP is 172.17.10.220.
ASA1 has two interfaces say x and y.
x has IP 172.17.100.7
y has IP 172.17.101.7
sh ip route on ASA1 shows
route x 0.0.0.0 0.0.0.0 172.17.100.254
route y 172.17.10.0 255.255.255.0  172.17.101.1
Need to know if i do below config on ASA1
http 172.17.10.220 255.255.255.255  which interface i should put there X  or Y?
Mahesh
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Mahesh,As long as the
Mahesh,
As long as the interface is reachable from the CSM server, either should work. Normally we have a higher security level (e.g., Inside) or management interface which we restrict and direct all management activity (CSM, ssh, snmp etc.) to use. That avoids unnecessary exposure of control plane services on untrusted networks.
Your routing path is independent of which interface allows the access. If interface y is the inside or highest security level then you could reach x via going "through" the ASA. If "x" is inside then your would need an access-list applied to "y" to allow the initiation of the connection from CSM.
That's correct.You are
That's correct.
You are talking to interface x (with a lower security level than you enter on so no need for an access-list to allow it) and your traffic is entering into (and returning from) the firewall via interface y.
Mahesh,
 Hi Marvin, Below is setup
Hi Marvin,
Below is setup here
ASA1 interface x has security level of 50
interface y has security level  of 70
Routing on ASA1
I have added the CSM to ASA as per below config
ASA1
http 172.17.10.220 255.255.255.255 x
With this config above ASA1 ia added to CSM successfully.
Thing i need to understand now is when CSM talks to ASA1 over interface X then
from Routing configured  on ASA1 as below
 which route it uses as next hop??
My understanding is that it should use route y 172.17.10.0 255.255.255.0 172.17.101
as it has more precise router????
Mahesh
That's correct.
69
