You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
Traffic flow on ASA
Are these config ok, as per need.
But till not working except SMTP
Requirement
* allow SMTP traffic from outside to host 80.1.2.3
* allow port 5512 from inside to outside for host 192.168.20.50
* allow inside host 192.168.1.10 to communiate on port 443 to dmz host 172.10.10.5
%%%%config%%%%
interface GigabitEthernet0/0
description "Connected to Internet"
speed 100
duplex full
nameif Outside
security-level 0
ip address 80.1.2.1 255.255.255.240
interface GigabitEthernet0/1
description "Connected to LAN"
speed 1000
duplex full
nameif inside
security-level 100
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/3
description "Connected to DMZ-SW"
speed 100
duplex full
nameif DMZ
security-level 50
ip address 172.10.10.1 255.255.255.0
access-list OUTSIDE extended permit tcp any host 80.1.2.3 eq smtp
access-list INSIDE extended permit tcp host 192.168.20.50 any eq 5512
access-list INSIDE extended permit tcp host 192.168.20.100 any eq SMTP
access-list DMZ extended permit tcp host 172.10.10.5 eq 443 host 192.168.1.10 eq 443
global (Outside) 1 interface
nat (inside) 1 192.168.20.50 255.255.255.255
static (inside,DMZ) 172.10.10.5 192.168.1.10 netmask 255.255.255.255
static (inside,Outside) 80.1.2.3 192.168.20.100 netmask 255.255.255.255
access-group OUTSIDE in interface Outside
access-group INSIDE in interface inside
access-group DMZ in interface DMZ
route Outside 0.0.0.0 0.0.0.0 80.1.2.2
  • Firewalling
Hall of Fame Super Blue
Re: Traffic flow on ASA
Nasr
So only SMTP to 80.1.2.3 is working ?
If so then
1) allow inside host 192.168.1.10 to communiate on port 443 to dmz host 172.10.10.5
you need to modify the config -
remove this from your config -
add this to your config
access-list INSIDE permit tcp host 192.168.1.10 host 172.10.10.5 eq 443
static (inside,DMZ) 192.168.1.10 192.168.1.10 netmask 255.255.255.255
2) allow port 5512 from inside to outside for host 192.168.20.50
your config for this should work.
Jon
Thanks Jon.
(1) Working
(2) I changed the PC and it started working, seems PC itself has an issue.
(*) ACL inside shows hits, can I clear those hits and by which command syntax.
(*) Local DNS Server needs to resolve Internet DNS address, do I need a static NAT with public IP or just allow ACL of DNS host with udp port 53 and add NAT(0) statemtnt
(*) Total of 2MB ISP Bandwith, is it possible to get report every 12 hours how much each service (SMTP) consumes bandwidth in/out
159
