Traffic Flow
I have a successfully setup a VPN connection through Cisco PIX 506 (E) 6.3(5)
But certain HTTP traffic to port 8080 doesnt seems to pass.
How do i check where its getting blocked
How can i check which traffic is going through the VPN tunnel
cheers
Ramp
1 REPLY
Green
Re: Traffic Flow
Are you trying a port translation in the firewall over the vpn? Something like this...
static (inside,outside) tcp 1.1.1.1 8080 192.168.1.10 80 netmask 255.255.255.255
If so are you then attempting http://1.1.1.1:8080 over the vpn?
You can check which traffic is going over the tunnel by looking at the pix config or by the route statistics on the vpn client.
111
