Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Traffic from inside that references the outside interface IP
     I have an ASA 5505 running 9.0 in routed mode. I have everything working fine with the exception of one item. I've set up port forwarding for the services that I need to have running such as HTTP, FTP, SSH, RDP etc... They all work from outside of the ASA, however if I were to reference the the webservers URL internally, it will not work.  So externally works however, if I use this same URL behind from a host on the inside interface it will not work.  I also cannot ping the external interface from inside the network, but can from outside of the ASA.  My outside interface is obtaining an IP address via DHCP from my provider.  My config is below.
Thanks in advance for any input!
ASA Version 9.0(1)
hostname tazasa
domain-name default.domain.invalid
enable password 8Ry2YjIyt7RRXU24 encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
xlate per-session permit tcp any4 any4
passwd lUgE9AXej18.2X7v encrypted
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
boot system disk0:/asa901-k8.bin
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network centos_www
description centos_www
object network NAS_FTP
description NAS_FTP
object network centos_ssh
description centos_ssh
object network Remote_Desktop_2
description Remote_Desktop_2
object network Remote_Desktop_1
description Remote_Desktop_1
object network Drive_CAM
description Drive_CAM
object network Door_CAM
description Door_CAM
object network ebooks_gateway
description ebooks_gateway
object network Linksys_phone
description Linksys_Phone
object network Inside_network
description Inside_Network
object network obj_any
description obj_any
object network xbox_3074_tcp
description xbox_3074_tcp
object network xbox_3074_udp
description xbox_3074_udp
object network centos_tftp
description centos_tftp
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit ip any any
access-list global_access extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
asdm image disk0:/asdm-711-52.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (any,outside) static interface service tcp www www
nat (any,outside) static interface service tcp ftp ftp
nat (any,outside) static interface service tcp ssh ssh
nat (any,outside) static interface service tcp 3390 3390
nat (any,outside) static interface service tcp 3389 3389
nat (any,outside) static interface service tcp 9101 9101
nat (any,outside) static interface no-proxy-arp service tcp 9100 9100
nat (any,outside) static interface service tcp 8888 8888
nat (any,outside) static interface service tcp sip sip
nat (inside,outside) dynamic interface
nat (any,outside) static interface service tcp 3074 3074
nat (any,outside) static interface service udp 3074 3074
nat (any,outside) static interface service udp tftp tftp
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
access-group global_access global
route inside 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication enable console LOCAL
http server enable
http inside
http inside
http outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
username ****** password nWdS.kwFG0AJMUCx encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
  inspect http
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
profile CiscoTAC-1
  no active
  destination address http
  destination address email
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
hpm topN enable
Super Bronze
Seems like a problematic situation to me.
Usually one easy way to is to use DNS rewrite so that the when the client asks the DNS server for the public IP address of the server then the ASA would modify the DNS reply to actually point to the local IP address of the server before returning the DNS reply to the client. But as you are using Static PAT (Port Forward) then this to my understanding is not possible.
One other usual option is to do a special NAT so that you can connect to the server from your LAN with the public IP address but since you mention that your ASA gets its public IP address with DHCP we really dont have a way of knowing if the IP address will change at some point (usually it tends to say the same, for me atleast) and would make the NAT configurations useless.
You might therefore want to consider modifying the clients local settings so that they connect to the local IP address the server when you connect to the certain DNS name. On Windows hosts this can naturally be done with the host file.
- Jouni
