Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Traffic goes from ASA & comeback on same problem
My internet link is connected on Internet Router & below downwards Cisco ASA 5520 is connected.ASA is connected with core switch cisco 4510 on downwards.
our webbased mail url owa.test.com is hosted outside.
Lets suppose ISP pool is 4.4.4.0/28.suppose owa server is Static natted on ASA with 4.4.4.4. my machine traffic is going to internet with same ISP with the help of PAT on Cisco ASA & internet is working on my machine. if i want to access owa.test.com or ip base for mail access, its not working & also it is not pinging. i suppose to ASA is blocking for returning traffic.
is there any way to traffic will go via same Firewal & comeback on same firewall port?
Please help us how to resolve it.
Vinod Kumar Gupta
9810966625
1 REPLY
Super Bronze
Re: Traffic goes from ASA & comeback on same problem
What I understand from your post the situation is the following
  • You have a mail server on your inside network
  • Its NATed to a public IP from your ISP
  • The public IP has DNS name of owa.test.com associated with it
  • You are connecting to the mail server from your inside network with the DNS name?
If this is the case can you please provide me with the following information
  • the "static" command for the mail server (you can leave out the actual IPs if needed)
  • Is the DNS server you local computer uses located in the Internet or your local network?
I think you will need the ASA to handle the DNS replies that are coming from a DNS server from the outside network
This would require that you have a "dns" parameter in your "static" nat command for the mail server.
For example likes this (presuming you are running software 8.2 or earlier):
static (inside,outside) 4.4.4.4 x.x.x.x netmask 255.255.255.255 dns
If you are running 8.3 or newe software the same would be
object network MAIL-SERVER
host x.x.x.x
nat (inside,outside) static 4.4.4.4 dns
Hope this helps.
Please rate if it was any of any help
- Jouni
216
