traffic inside GTP
I'm searhing for an info. Is it possible to inspect traffic inside the GTP tunnel passing through ASA or FWSM?
Silver
Re: traffic inside GTP
You can use the feature of GTP inspection in PIX/ASA ver 7.x. Following link may help you
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/inspect.html#wp1144252
I've found that document, but that doesn't say anything about the traffic inside the tunnel. I wondered if there are some specific way to dig in.... Using "show connection" you can see only GTP control and data connections.
123
