transparent mode Firewall with 4 ports transparent mode Firewall with 4 por
Dears,
i have Firewall with 4 ports FE is configured as transparent mode..... how many interfaces i can configure in this mode.
i heared just one output interface and one input interface i can configure in this mode...is that true?
or can i configure 2 FE as output and 2 FE as Input.
thx for any advice or help.
Re: transparent mode Firewall with 4 ports transparent mode Fire
Kindly provide the software and hardware details of your firewall.
regards
Sachin Verma
it is ASA5510 and software ASA Version 7.2(2) .
Dou you have info about this ?
Can you configure only 2 or 4 interfaces ?
Greetings,
Accoding to the ASA manual:
Note Transparent firewall mode allows only two interfaces to pass through traffic; however, on the The ASA 5510 and higher adaptive security appliance, you can use the Management 0/0 interface (either the physical interface or a subinterface) as a third interface for management traffic. The mode is not configurable in this case and must always be management-only.
Also if you desire yopu can configure your device in multiple context mode and use all 4 interfaces. 2 for each context.
Hope this helped.
149
