trouble with removing NAC and letting traffic through
All,
I have a simple network setup that at once had a NAT setup on it. I am trying to remove it so the IP from the inside is the same when it goes past the outside interface. It was originally setup with a global NAT and static entries. I removed the NAT and left the static entries. As long as I have the startic entry with it translating it from one subnet to the other the traffic gets through (example: static (inside,outside) 172.16.100.3 172.16.100.66 netmask 255.255.255.255 ). But when I adjust the static statement to reflect the same IP ( static (inside,outside) 172.16.100.66 172.16.100.66 netmask 255.255.255.255 ) the traffic does not get to the router. I have tried removing the static route all togehter and it does not do any good either. I tried using a Identity NAT statement, but that did not seem to work with the static (using the same IP, if I had the statement set to translate like in the first example it worked) or without. Since I am very new to working with Firewalls and I did not set this up I want to run this by some more professional eyes. Below is the entire FW configuration. If you need more information please ask. If you need the router config I can post it, but I really think it is a Firewall problem and it has to do with going between 2 different subnets (inside and outside interfaces). I need to set it up so IP from inside is retained when it goes past the outside interface. Any help would be appreciated
Glenn
Firewall configuration
ASA Version 7.0(8)
hostname Firewall1
enable password iMImA2JOC1SD encrypted
passwd 2KFQnbNIdI. encrypted
names
name 172.16.100.1 PERIM-RTR
dns-guard
interface Ethernet0/0
duplex full
nameif outside
security-level 0
ip address 172.16.100.2 255.255.255.224
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.16.100.65 255.255.255.224
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
access-list acl_out extended permit ip any any
access-list acl_in extended permit ip any any
pager lines 24
logging enable
logging timestamp
logging monitor notifications
logging buffered debugging
logging trap informational
logging asdm informational
logging host inside 172.16.100.66
logging debug-trace
mtu outside 1500
mtu inside 1500
mtu management 1500
icmp permit any outside
asdm image disk0:/asdm-508.bin
no asdm history enable
arp timeout 14400
static (inside,outside) 172.16.100.5 172.16.100.68 netmask 255.255.255.255
static (inside,outside) 172.16.100.6 172.16.100.69 netmask 255.255.255.255
static (inside,outside) 172.16.100.7 172.16.100.70 netmask 255.255.255.255
static (inside,outside) 172.16.100.8 172.16.100.71 netmask 255.255.255.255
static (inside,outside) 172.16.100.9 172.16.100.72 netmask 255.255.255.255
static (inside,outside) 172.16.100.10 172.16.100.73 netmask 255.255.255.255
static (inside,outside) 172.16.100.11 172.16.100.74 netmask 255.255.255.255
static (inside,outside) 172.16.100.12 172.16.100.75 netmask 255.255.255.255
access-group acl_out in interface outside
access-group acl_in in interface inside
route outside 0.0.0.0 0.0.0.0 PERIM-RTR 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 0.0.0.0 0.0.0.0 inside
http 172.16.100.70 255.255.255.70 inside
http 172.16.100.66 255.255.255.255 inside
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable management
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect dns maximum-length 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
service-policy global_policy global
Everyone's tags (2)
1 REPLY
Hi Glenn,
What does the output of  'show ip route 172.16.100.66' on the router give you?
-Mike
333
