Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
True OOB management on ASA
I was just curious if anyone heard any Cisco's plans to implement a true OOB management interface on ASAs, so this interface does not use the global routing table (has some kind of a default GW for itself or maybe a policy based routing statement), the current implementation of "management-only" is pretty much useless (I can put such interface in my management vlan/subnet but what if I have remote VPN devices connected to this ASA that also need to access the same management vlan?)
Re: True OOB management on ASA
You can make a separate context and place only the management interface in it.
However you will loose the VPN functionality as soon as you go to 'multiple' context mode :)
Farrukh
Community Member
Exactly, there will be no VPN functionality, which is the problem. Something similar to VRF-Lite on ASA without the VPN restrictions of multi context would be perfect.
You can request this feature through your local Cisco AM/SE. If many people request it, it has high likelihood of appearing in future software releases.
Farrukh
Community Member
A true OOB management would be very useful!
Without a separate routing instance this interface is useless.
601
