Trunking between an IPS 4240 and an ASA 5510
I have a requirement at a client site wherein I am tasked with separating VLANs near the edge.
I have to have a trunk between the ASA and the IPS which will carry the two VLANs.
Is this possible?
Thank You in advance!
1 ACCEPTED SOLUTION
Bronze
Kevin,
That is correct.
Example:
interface g0/1.10
vlan 10
nameif outside1
ip address 10.10.10.1 255.255.255.0
Felipe.
Remember to rate useful posts.
Bronze
Hello Kevin,
I think this is better to posted on the IPS than the ASA Forum.
The ASA just needs to be configured with sub-interfaces.
On the IPS I think inline Vlan Pairs will work.
http://www.cisco.com/en/US/docs/security/ips/5.1/configuration/guide/cli/cliInter.html#wp1047718
I found this link which explains it well.
http://popravak.wordpress.com/2012/03/30/cisco-ips-scenario-three-inline-vlan-pairs/
I hope it helps
Felipe.
Thank you for the response.
is it correct to say then that the subinterfaces ont he ASA would be configured to trunk to a switch by creating subinterfaces just like you would on a router that you wanted to trunk to?
Thanks again!
Bronze
Kevin,
That is correct.
Example:
interface g0/1.10
vlan 10
nameif outside1
Felipe.
Thank You!
199
