Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Tunnel not comming up
My vpn tunnel is not comming up and I am having the following error, which I donot understand.
Aug 03 16:41:41 [IKEv1]: Group = 80.5.93.129, IP = 80.5.93.129, Removing peer from correlator table failed, no match!
Aug 03 16:41:44 [IKEv1]: Group = 80.5.93.129, IP = 80.5.93.129, QM FSM error (P2 struct &0x3baf170, mess id 0xb8cae8a5)!
Aug 03 16:41:44 [IKEv1]: Group = 80.5.93.129, IP = 80.5.93.129, Removing peer from correlator table failed, no match!
Aug 03 16:41:50 [IKEv1]: Group = 80.5.93.129, IP = 80.5.93.129, QM FSM error (P2 struct &0x3baf170, mess id 0x83c03218)!
Aug 03 16:41:50 [IKEv1]: Group = 80.5.93.129, IP = 80.5.93.129, Removing peer from correlator table failed, no match!
this ip is my remote peer.
Gold
Re: Tunnel not comming up
post the configs from both peers.
offhand, sounds like somewhere your peer statements aren't matching.
Community Member
Here is my config.
access-list inside_nat0_outbound extended permit ip host 192.168.11.1 host PDS
access-list outside_70_cryptomap extended permit ip host 192.168.11.1 host PDS
access-list inside_nat_outbound extended permit ip object-group Listening host PDS
global (outside) 3 192.168.11.1 netmask 255.255.255.0
nat (inside) 3 access-list inside_nat_outbound
crypto map vpn 70 match address outside_70_cryptomap
crypto map vpn 70 set pfs
crypto map vpn 70 set peer 143.252.4.36
crypto map vpn 70 set transform-set ESP-3DES-SHA
crypto map vpn 70 set security-association lifetime seconds 3600
crypto isakmp policy 30
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto map vpn interface outside
crypto isakmp identity address
crypto isakmp enable outside
tunnel-group 143.252.4.36 type ipsec-l2l
tunnel-group 143.252.4.36 ipsec-attributes
pre-shared-key *
From: Rafiq, Mohammed [mailto:Mohammed.Rafiq@newsint.co.uk]
Sent: 03 August 2007 17:18
To: Hassan Daher
Subject: RE: change Req 214109 (VPN to TLC)
access-list internet_cryptomap_120 extended permit tcp host 10.10.126.140 host 192.168.11.1 eq www
nat (optfir) 0 access-list optfir_nat0_outbound
crypto ipsec transform-set ESP_3DES_SHA esp-3des esp-sha-hmac
crypto map Thus_map 120 match address internet_cryptomap_120
crypto map Thus_map 120 set pfs
crypto map Thus_map 120 set peer 80.5.93.129
crypto map Thus_map 120 set transform-set ESP-3DES-SHA
crypto map Thus_map 120 set security-association lifetime seconds 3600
crypto map Thus_map interface internet
isakmp enable internet
isakmp enable webcss
isakmp policy 30 authentication pre-share
isakmp policy 30 encryption 3des
isakmp policy 30 hash sha
isakmp policy 30 group 2
isakmp policy 30 lifetime 86400
tunnel-group 80.5.93.129 type ipsec-l2l
tunnel-group 80.5.93.129 ipsec-attributes
pre-shared-key *
Your match address statements does not match on both sides. One side is matching on IP and the other on TCP port 80.
175
