Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
turn on logging/timestamping on vers 6.3.5 code
What is the syntax to turn on date and timestamp for logging console on this vers of code for a 506e? I have logging on, logging timestamp, logging buff debugg, date and time are correct...can't seem to get timestamp on the log enties.
Hall of Fame Super Blue
Re: turn on logging/timestamping on vers 6.3.5 code
"Logging timestamp" shoud have done the trick. I just tested it in our lab : Pix 506E with 6.3(5)
Without timestamp:
Apr 23 10:38:59 10.228.53.195 ProdtoDTE %PIX-5-111008: User 'enable_15' executed the 'configure t' command
With timestamp:
Apr 23 10:39:18 10.228.53.195 Apr 23 2007 11:06:56 ProdtoDTE : %PIX-5-111008: User 'enable_15' executed the 'write mem' command.
Are you not seeing this ?
Jon
Jon, this is what I get. I turned logging on again >> logging on
logging timestamp
logging buffered debugging <<<<<<
502103: User priv level changed: Uname: dgalati From: 1 To: 15
111008: User 'dgalati' executed the 'enable' command.
710002: UDP access permitted from to
111001: Begin configuration: console writing to memory
111004: console end configuration: OK
111008: User 'dgalati' executed the 'write mem' command.
111009: User 'dgalati' executed cmd: show clock
111009: User 'dgalati' executed cmd: show logging
111007: Begin configuration: console reading from terminal
111008: User 'dgalati' executed the 'configure t' command.
111008: User 'dgalati' executed the 'clock set 10:30:20 23 April 2007' command.
111005: console end configuration: OK
providencefw#
Green
My experience is if you do a show run from the console the timestamps will not display, but if you look at the syslogs the timestamps will be there.
Hi, I won't see timestamps in the active mem (sh run) will I ?? I am NOT seeing them in my sh log via ssh. Haven't looked at the syslog server yet...thx.
Green
Sorry, typo, I meant "show log". haha
found out we don't use syslog per se...just HPOV, etc. I've got one other reply from someone else on this, waiting to see if I can get it timestamping on this old vers pix code...I think we did get it working last week on another old vers code but not this one...hate the old code period...BTW-your last name is the name of the OLD Chicago WHite Sox Park - Comiskey Park.
165
