Two Different Policy Map with same inspect
Hi Everyone,
I know we can have only 1 global policy on ASA that apply to all the interfaces.
Say we have global policy map that has FTP checked for inspection.
ASA1#                                   sh run policy-map
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
ASA1#  sh run class-map
class-map inspection_default
description Class MAP name is inspection_default
match default-inspection-traffic
Above we have default class and inspection.
For testing purposes i create another class and policy map and apply to DMZ interface
class-map Class-DMZ
        description TEST
      policy-map DMZ-FTP
        description TEST
        class Class-DMZ
          inspect ftp
      service-policy DMZ-FTP interface DMZ.
Now we have same FTP inspection under global and DMZ interface.
How does and under which order FTP inspection works?
MAhesh
1 ACCEPTED SOLUTION
Re: Two Different Policy Map with same inspect
Interface-specific inspection rules always take precednece over those in the global policy, if applied to the same traffic class (class-map). So for FTP inspection in your case the service policy, applied to the DMZ interface will take care of FTP traffic.
Many thanks Andrew
Mahesh
229
