Two outside interface
I have got the cisco ASA 5520 with the following ip address:
Example purpose only:
Outside5: 8.8.8.0/24 (connected to ISP1)
interface5: 10.10.0.0/16 (Connected to LAN)
static (interface5,outside5) 8.8.8.8 10.10.10.10 netmask 255.255.255.255
I have got the above scenario and working well on the live environment.
Now I am planning to add another ISP as follows:
Outside10: 7.7.7.0/24 (Connected to ISP2)
Upto this their will be no any trouble.
But will the following statement works ? If it does work how will it route ?
static (interface5,outside10) 7.7.7.7 10.10.10.10 netmask 255.255.255.255
Mero
1 ACCEPTED SOLUTION
Super Bronze
To my understanding the inbound connections will work from both ISPs to this hosts and connections from each ISP will have their return traffic forwarded according to the existing XLATE on the firewall.
However when the actual server forms a connection outbound it will only use the ISP which holds the current active default route.
- Jouni
Super Bronze
It will probably work for the incoming/inbound connections towards the IP address 7.7.7.7. Connection will come through the ISP2 and return traffic will flow through ISP2 also.
I think however that the host 10.10.10.10 will only form outbound connections through ISP1 if its holding the default route.
- Jouni
Will the inbound traffic come from isp1 also.
Actually 10.10.10.10 is the public web server and I want to maintain isp fail over. Will this concept work ? Both public ip will be registered as dns.
Super Bronze
- Jouni
91
