Two public networks on ASA outside interface
exonetinf1nity
Greetings, we have an MPLS network configured, the head office has a 10Mbit Ethernet circuit comming into the HQ which is split into two dot1q vlans. This link terminates on a 3825 ISR.
The internet vlan is bridged from the router onto the outside interface of the firewall which isnt a problem...however the ISP has provided two address blocks
A /30 for the dot1q Vlan internet link and a /28 for external business services such as SMTP.
Now currently i have the /30 terminated on the outside of the firewall, if i setup NAT statements on the firewall for the /28 range and get the ISP to route to the /28 network through the /30 network would this work ok.
If configs are needed please let me know.
We were going to use a common gateway initially but the customer wants both the firewall and router connected to the internal network, at present the /30 is bridged onto f0/0/0 which connects to the outside of the asa.
The other options i was considering was to assign the /30 address to g0/1.1001 being 193.***.***.170 255.255.255.252 and then assign the first avaliable address in the /28 range to vlan 1 then the next address in the /28 range to the outside of the firewall.
ASA
interface ethernet 0/0
ip address 193.***.***.170 255.255.255.252
nameif outside
security-level 0
interface ethernet 0/1
ip address 10.171.41.252 255.255.255.0
nameif inside
security-level 90
route inside 10.170.0.0 255.255.255.0 10.171.41.1
route inside 10.171.0.0 255.255.255.0 10.171.41.1
route outside 0.0.0.0 0.0.0.0 195.***.***.169
ISR
interface GigabitEthernet0/0
no ip address
media-type rj45
negotiation auto
speed auto
duplex auto
interface GigabitEthernet0/0.1 - Connection to Customer Internal Lan
ip address 10.171.40.1 255.255.255.0
encapsulation dot1q 1
interface GigabitEthernet0/0.50 - Connection to Customer Internal Lan
ip address 10.170.40.1 255.255.255.0
encapsulation dot1q 50
interface GigabitEthernet0/1 - Connection to MPLS Circuit
no ip address
media-type rj45
negotiation auto
speed 10
duplex full
interface GigabitEthernet0/1.1000 - Connection to MPLS Network
ip address 172.18.255.2 255.255.255.252
encapsulation dot1q 1000
interface GigabitEthernet0/1.1001 - Connection to Internet
no ip address
encapsulation dot1q 1001
bridge-group 1
interface FastEthernet0/0/0 - Connection to ASA Outside interface
speed 100
duplex full
bridge-group 1
interface FastEthernet0/0/1
speed 100
duplex full
interface FastEthernet0/0/2
speed 100
duplex full
interface FastEthernet0/0/3
interface vlan 1
no ip address
bridge-group 1
ip route 0.0.0.0 0.0.0.0 10.171.40.252 - ASA Inside interface for MPLS Remote site to Internet Traffic
ip route 10.171.0.0 255.255.255.0 172.18.255.1 - Route to all other remote sites via PE
ip route 10.170.0.0 255.255.255.0 172.18.255.1 - Route to all other remote sites via PE
suschoud
YES.
Firewall would start proxy arp'ing for the other subnet as soon as it is specified in nat statements.If isp routes to f/w for this other subnet,everything would work well.
Sushil
suschoud
YES.
Sushil
Tried it and worked a treat, thank you very much for your time.
