Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
udp port 53 issue
hello folks!!!
We have created an ACL to allow TCP and UDP port 53 to/from DMZ and Inside Network. When we use packet-tracer tool through ASDM to verify the connectivity from DMZ to inside interface UDP packet gets dropped.
When we test the same port_53 using TCP it works perfectly fine.
We are getting error (inspect-dns-invalid-pak)DNS Inspect Invalid Packet.
Kindly Help us troubleshoot the problem.
1 REPLY
Re: udp port 53 issue
Joseph
From CCO:
inspect-dns-invalid-pak - This counter will increment when the security appliance detects an invalid DNS packet. For example, a DNS packet with no DNS header, the number of DNS resource records not matching the counter in the header, etc.
Is DNS resolution from inside to DMZ not working ? browsing etc ? This is just an information message.. nothing serious here..
DNS is on DMZ right ?
Raj
155
