Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
UDP reverse path check
ASA running 8.2(5).
When I enable ip spoofing on my network interfaces I see this getting logged:
Deny UDP reverse path check from 10.100.100.102 to 10.100.100.255 on interface SPECTRA-LAN
This is because interface SPECTRA-LAN (VLAN50) is the interface connected to the network with ip 10.100.100.0/24 but the interface do not have a ip address so it does not exist in the routing table I believe?
However interface INTERN do also belong to network 10.100.100.0/24 which also is the management interface and the default route for hosts in network 10.100.100.0/24, but has no vlan.
How do I solve this?
1. move the management0/0 to SPECTRA-LAN and give SPECTRA-LAN ip 10.100.100.1?
2. give SPECTRA-LAN a ip address in the 10.100.100.0 range?
3. or ??
My routing table and interface list is:
Current available interface(s):
  DATA-BACKUP     Name of interface Redundant1.10
  DMZ             Name of interface Redundant1.900
  GUEST           Name of interface Redundant1.990
  HOSTING         Name of interface Redundant1.100
  Infrastruktur   Name of interface Redundant1.20
  Intern          Name of interface Management0/0
  OUTSIDE-BACKUP  Name of interface Redundant1.998
  PHONE           Name of interface Redundant1.200
  SPECTRA-LAN     Name of interface Redundant1.50
  outside         Name of interface Ethernet0/3
Gateway of last resort is 1.2.3.4 to network 0.0.0.0
C    172.31.0.0 255.255.255.0 is directly connected, DMZ
S    192.168.200.46 255.255.255.255 [1/0] via 1.2.3.4, outside
S    192.168.200.47 255.255.255.255 [1/0] via 1.2.3.4, outside
S    VPN-hosting 255.255.255.0 [1/0] via 192.168.200.1, outside
C    93.167.197.80 255.255.255.240 is directly connected, outside
S    10.100.110.0 255.255.255.0 [1/0] via 10.100.110.1, outside
C    10.10.10.0 255.255.255.0 is directly connected, GUEST
C    10.100.100.0 255.255.255.0 is directly connected, Intern
S    10.100.101.0 255.255.255.0 [5/0] via 10.100.100.252, Intern
S    10.100.0.0 255.255.0.0 [10/0] via 10.100.100.252, Intern
C    10.200.100.0 255.255.252.0 is directly connected, PHONE
C    10.199.1.0 255.255.255.0 is directly connected, Infrastruktur
C    10.199.0.0 255.255.255.0 is directly connected, DATA-BACKUP
C    192.168.254.0 255.255.255.0 is directly connected, HOSTING
S*   0.0.0.0 0.0.0.0 [1/0] via 1.2.3.4, outside
S    192.168.0.0 255.255.0.0 [5/0] via 192.168.254.1, HOSTING
Robert
Everyone's tags (3)
The reason why you are seeing that error message is because 10.100.100.102 is connected to the wrong subnet/VLAN. It should have been connected to the Intern subnet/VLAN, however, it has incorrectly assigned/conencted to SPECTRA-LAN subnet.
Just configure 10.100.100.102 host correctly by assigning it to the correct VLAN, and you won't have that error anymore.
You can't have 2 VLANs in the same subnet.
Re: UDP reverse path check
As far as I can see it is not the case where I have 2 vlans in the same subnet.
Looking in ASDM I see:
Management0/0 interface = security level 100 = Intern = native vlan (ip address 10.100.100.1)
Redundant1.50 interface = security level 100 = SPECTRA-LAN = vlan50 (no ip address)
Subnet 10.100.100.0/24 must belong to vlan50.
Redundant1 is ethernet0/0 and ethernet0/1. Configuration allows communication between interfaces with same security level. All acl policies from subnet 10.100.100.0/24 is bound to interface and acl from allows all traffic to any less secure network.
I´m currently not sure how the fysical cabling is connected, but I´ll have to look as it seems traffic from subnet 10.100.100.0/24 can come in from both management0/0 and the redundant interfaces eth0/0 + eth0/1 ??
Does this make sence at all ?
Robert
As per your above statement, 10.100.100.0/24 belongs to native vlan (Intern), not vlan50 (SPECTRA-LAN).
Eventhough SPECTRA-LAN is not configured with any ip address, the subnet 10.100.100.0/24 can't belong to this vlan50 as it already belong to Intern (native vlan) subnet.
958
