Unable to add ports to forward SIP UDP and RTP 10000-20000
This is what I am trying to add...
object network voice-sip-tcp
 host 192.168.1.65
 nat (inside,outside) static interface service tcp sip sip
^^^ this was succesful!
object network voice_sip_udp
 host 192.168.1.65
 nat (inside,outside) static interface service udp sip sip
^^^ this resulted in....ERROR: NAT unable to reserve ports.
object service rtp_ports
 service udp source range 10000 20000
object network voice_inside
 host 192.168.1.65
^^^ Success!
nat (inside,outside) source static voice_inside interface service rtp_ports rtp_ports
^^^ this resulted in ....ERROR: NAT unable to reserve ports.
here is the full config...
: Saved
ASA Version 8.4(5)
hostname xxx-gw
domain-name office.xxx.local
enable password xxx encrypted
passwd xxx encrypted
names
name 192.168.1.9 thunder
name 192.168.1.21 carol
name 192.168.1.55 konica
name 192.168.1.23 dannielle
name 192.168.1.25 brittany
name 192.168.1.24 jeanie
name 192.168.1.65 phonesystem
name 192.168.1.2 wifirouter
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 nameif inside
 security-level 100
interface Vlan2
 nameif outside
 security-level 0
 ip address xxx 255.255.255.248
interface Vlan3
 description dmz
 no nameif
 no security-level
 no ip address
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
 name-server thunder
 name-server xxx
 name-server xxx
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
 subnet 0.0.0.0 0.0.0.0
object network obj-192.168.1
 subnet 192.168.1.0 255.255.255.0
object network xxx_PHONE_SERVER
 host 192.168.1.65
object service TCP_TO_xxx
 service tcp destination eq 44
object service UDP_TO_xxx
 service udp destination eq 44
object service xxx_SSH
 service tcp source eq ssh
object service tcp_44
 service tcp source eq 44
 host 192.168.1.65
 host 192.168.1.65
 host 192.168.1.65
object-group network VPN-POOLS
 network-object 192.168.100.0 255.255.255.0
 network-object 192.168.101.0 255.255.255.0
access-list FROM-INTERNET extended permit icmp any any echo
access-list FROM-INTERNET extended permit icmp any any echo-reply
access-list FROM-INTERNET extended permit icmp any any time-exceeded
access-list FROM-INTERNET extended permit icmp any any unreachable
access-list FROM-INTERNET extended permit udp any eq domain any log
access-list FROM-INTERNET extended permit ip any any log
access-list FROM-INTERNET extended permit tcp any object xxx_PHONE_SERVER eq ssh
access-list FROM-INTERNET extended permit udp any any eq sip
access-list FROM-INTERNET extended permit tcp any any eq sip
access-list FROM-INTERNET extended permit udp any any range 10000 20000
access-list NO-NAT extended permit ip 192.168.1.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list VPN-SPLIT remark Corporate LAN
access-list VPN-SPLIT standard permit 192.168.1.0 255.255.255.0
access-list VPN-CAP extended permit ip 192.168.100.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list VPN-CAP extended permit ip 192.168.1.0 255.255.255.0 192.168.100.0 255.255.255.0
pager lines 24
logging enable
logging timestamp
logging buffered debugging
logging asdm warnings
mtu inside 1500
mtu outside 1500
ip local pool VPN-POOL 192.168.100.240-192.168.100.250
ip local pool SSLVPN-POOL 192.168.101.240-192.168.101.250
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source static obj-192.168.1 obj-192.168.1 destination static VPN-POOLS VPN-POOLS
 nat (inside,outside) dynamic interface
object network AYS_PHONE_SERVER
 nat (inside,outside) static interface service tcp ssh 44
access-group FROM-INTERNET in interface outside
route outside 0.0.0.0 0.0.0.0 23.31.109.81 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
snmp-server location tele-closet
snmp-server contact itadmin@xxx.com
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set WINMAC-VPN esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set WINMAC-VPN mode transport
crypto ipsec ikev1 transform-set IPSEC-VPN esp-aes-256 esp-sha-hmac
crypto ipsec security-association lifetime seconds 3600
crypto dynamic-map OUTSIDE_VPN_MAP 20 set ikev1 transform-set WINMAC-VPN IPSEC-VPN
crypto map VPN-TUNNEL 65535 ipsec-isakmp dynamic OUTSIDE_VPN_MAP
crypto map VPN-TUNNEL interface outside
crypto ca trustpoint _SmartCallHome_ServerCA
 crl configure
crypto ca trustpoint localtrust
 enrollment self
 fqdn sslvpn.xxx.com
 subject-name CN=sslvpn.xxx.com
 crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
 certificate ca
      xxxxxx
  quit
crypto ikev1 enable outside
crypto ikev1 policy 10
 authentication pre-share
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 20
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 50
 encryption aes-256
 hash sha
 group 5
 lifetime 28800
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 45
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access inside
dhcpd dns xxxxx
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server xxxx
ssl trust-point localtrust outside
webvpn
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
 dns-server value xxxxx
 vpn-tunnel-protocol ikev1
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value VPN-SPLIT
group-policy IPSEC-VPN internal
group-policy IPSEC-VPN attributes
 dns-server value xxxxxx
username asa password DFQtD4MVvSnK9rG3 encrypted privilege 15
username carol.mccauley password xxxxxx nt-encrypted privilege 15
username carol.mccauley attributes
 vpn-group-policy DefaultRAGroup
 vpn-tunnel-protocol ikev1 l2tp-ipsec
username dannielle.shifflett password xxxxxx nt-encrypted privilege 15
username dannielle.shifflett attributes
username pete.akey password xxxxx nt-encrypted privilege 15
username pete.akey attributes
tunnel-group DefaultRAGroup general-attributes
 address-pool VPN-POOL
tunnel-group DefaultRAGroup ipsec-attributes
 ikev1 pre-shared-key *****
tunnel-group DefaultRAGroup ppp-attributes
 no authentication chap
 authentication ms-chap-v2
tunnel-group IPSEC-VPN type remote-access
tunnel-group IPSEC-VPN general-attributes
 default-group-policy IPSEC-VPN
tunnel-group IPSEC-VPN ipsec-attributes
tunnel-group IPSEC-VPN ppp-attributes
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  no dns-guard
  no protocol-enforcement
policy-map global_policy
 class inspection_default
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
Cryptochecksum:xxxxxx
: end
Hi,I think these ports must
I think these ports must be used already on the translations on the ASA device for the Interface IP using this statement:-
If you would like to forward all these ports on the ASA from the interface IP , you might have to clear the xlate table first and then apply this Static NAT statement.
This should be same for the UDP port 5060.
You can use these commands to check:-
show xlate global <Outside interface IP>
show conn port 5060-5061
Thanks and Regards,
Vibhor Amrodia
ok thanks!...this was very
ok thanks!...this was very helpful, I could get the sip UDP port to work by...
- turning off the phone server
- clear xlate
-  object network voice_sip_udp
however, I cannot clear the xlates and connections fast enough to apply this....
 - nat (inside,outside) source static voice_inside interface service rtp_ports rtp_ports
I still get the "ERROR: NAT unable to reserve ports."
Hi,This would be difficult to
This would be difficult to implement on the ASA device as you would already have a lot of xlate already using the range 10000-20000.
I think the best way to apply this would be to break this range into smaller parts.. For ex:-
10000 15000 and see if that works. But still would be difficult.
Is there any specific reason for doing this on the ASA device ?
Thanks and Regards,
Vibhor Amrodia
1387
