Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Unable to ping ASA interfaces (ASA intra-interface)
I can not ping the DMZ hosts from my Inside or from other interface Network and vice-versa
mention below is my ASA Config:
: Saved
ASA Version 8.0(5)
hostname Test
domain-name default.domain.invalid
dns-guard
interface Ethernet0/0
description + + + + Connection to Internet (Outside) + + + +
nameif outside
security-level 0
ip address 202.X.X.X 255.255.255.224
interface Ethernet0/1
description + + + + Connection to LAN (Inside) + + + +
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.0
interface Ethernet0/2
nameif DMZ
security-level 100
interface Ethernet0/3
description VV
nameif VV
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Management0/0
nameif management
security-level 100
ip address 172.16.1.1 255.255.255.0
management-only
boot system disk0:/asa805-k8.bin
no ftp mode passive
clock timezone IST 5 30
dns domain-lookup outside
dns domain-lookup inside
dns server-group DefaultDNS
name-server 203.122.X.X
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list 110 remark + + + +  OUTSIDE + + + +
access-list 110 extended permit icmp any any
access-list 110 extended permit icmp any any echo
access-list 110 extended permit icmp any any echo-reply
access-list 110 extended permit icmp any any source-quench
access-list 110 extended permit icmp any any unreachable
access-list 110 extended permit icmp any any time-exceeded
access-list 120 remark + + + + INSIDE + + + +
access-list 120 extended permit icmp any any
access-list PropRem_splitTunnelAcl remark VPN_Client_local_Lan_access
access-list PropRem_splitTunnelAcl standard permit host 0.0.0.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
mtu VV 1500
mtu management 1500
ip local pool R_IP_vpn 192.168.0.240-192.168.0.250 mask 255.255.255.0
ip local pool R_IP_VPN2 192.168.1.240-192.168.1.250 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any DMZ
arp timeout 14400
nat-control
global (outside) 1 interface
global (outside) 2 202.63.X.X netmask 255.255.255.224
global (outside) 3 202.63.X.X netmask 255.255.255.224
global (outside) 4 202.63.X.X netmask 255.255.255.224
global (outside) 5 202.63.X.X netmask 255.255.255.224
nat (inside) 1 0.0.0.0 0.0.0.0
nat (DMZ) 1 0.0.0.0 0.0.0.0
static (DMZ,outside) 202.63.x.x 192.168.1.18 netmask 255.255.255.255
static (DMZ,outside) 202.63.X.X 192.168.1.11 netmask 255.255.255.255
static (inside,outside) 202.63.X.X 192.168.0.2 netmask 255.255.255.255
static (DMZ,outside) 202.63.X.X 192.168.1.20 netmask 255.255.255.255
static (DMZ,outside) 202.63.X.X 192.168.1.19 netmask 255.255.255.255
static (DMZ,outside) 202.63.x.x 192.168.1.10 netmask 255.255.255.255
static (DMZ,outside) 202.63.x.x 192.168.1.12 netmask 255.255.255.255
static (DMZ,outside) 202.63.x.x 192.168.1.6 netmask 255.255.255.255
static (DMZ,outside) 202.63.x.x 192.168.1.13 netmask 255.255.255.255
static (DMZ,outside) 202.63.x.x 192.168.1.7 netmask 255.255.255.255
static (DMZ,outside) 202.63.x.x 192.168.1.14 netmask 255.255.255.255
static (DMZ,outside) 202.63.x.x 192.168.1.2 netmask 255.255.255.255
static (DMZ,outside) 202.63.x.x 192.168.1.201 netmask 255.255.255.255
static (DMZ,outside) 202.63.x.x 192.168.1.202 netmask 255.255.255.255
static (DMZ,outside) 202.63.x.x 192.168.1.9 netmask 255.255.255.255
access-group 110 in interface outside
route outside 0.0.0.0 0.0.0.0 202.63.X.X 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
http server enable
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 20 set security-association lifetime seconds 28800
crypto dynamic-map outside_dyn_map 20 set security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto map DMZ_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map DMZ_map interface DMZ
crypto isakmp identity hostname
crypto isakmp enable outside
crypto isakmp enable DMZ
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
group-policy PropRem internal
group-policy PropRem attributes
dns-server value 4.2.2.2 203.X.X.x
split-tunnel-policy tunnelspecified
split-tunnel-network-list value PropRem_splitTunnelAcl
tunnel-group PropRem type remote-access
tunnel-group PropRem general-attributes
address-pool R_IP_VPN2
default-group-policy PropRem
tunnel-group PropRem ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
service-policy global_policy global
prompt hostname context
: end
Community Member
I required a desperate help on this.
Please help me some one
Community Member
You need to bound an access-list with icmp echo-reply statement on your dmz interface.
605
