Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Unable to ping from inside network to outside network
Hi, the ping initiated from inside network to outside hosts is dropping on outside interface. If i add acl entry to allow icmp on outside interface, ping is fin but this is asa 5540 (statefull firewall) that should remember connection initiated from inside network. This is production firewall used to allow internet surfing which works ok. Any idea where to start troublehoting would be greatly appreciated.
1 ACCEPTED SOLUTION
Gold
Re: Unable to ping from inside network to outside network
read this:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094e8a.shtml
it covers both icmp and traceroute issues through your firewall.
Green
It is not stateful for icmp traffic. You must explicitly allow it in an acl or enable icmp inspection. The ASA is acting as it should.
Gold
read this:
Community Member
Thank you gents.
I like ASA more and more..
Community Member
If you want to enable stateful ICMP inspection you can do this from global config
Type
policy-map global_policy
class inspection_default
inspect icmp
Community Member
Thank you all for prompt response; i setup asa as per cisco's doc (15246) and it is OK now.
325
