Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
unable to run ospf between two ASA's running l2l ipsec tunnel.
Hi All,
my scenario is as shown below :
R1>>ASA1>>internet>>ASA2>>R2
i have established the ipsec tunnel between the two ASA's. now, when i run ospf on both these ASA's ,they do not become neighbors. as per the cisco doc ASA allows OSPF unicast to work over the IPSEC tunnel.
kindly advise me on this.
waiting for reply.
thanks
kirti.
Re: unable to run ospf between two ASA's running l2l ipsec tunne
What does the interface configuration of the ASAs look like and what does your OSPF config on the routers look like?
the configs are as follows
on R1
router ospf 10
net 10.1.1.1 0.0.0.0 a 0 (loopback IP)
net 1.1.1.1 0.0.0.0 a 0
on the ASA1 outside interface e0/1 the config is:
int e0/1
nameif outside
sec 0
ip add 2.1.1.2 255.255.255.0
ospf net point-to-point non-broadcast
router ospf 10
net 1.1.1.2 255.255.255.255 a 0
net 2.1.1.2 255.255.255.255 a 0
net 3.1.1.0 255.255.255.0 a 0
neigh 3.1.1.2 int outside (this is the outside IP of the ASA2)
config on ASA 2
int e0/1
nameif outside
sec 0
ip add 3.1.1.2 255.255.255.0
router ospf 10
net 3.1.1.2 255.255.255.255 a 0
net 4.1.1.2 255.255.255.255 a 0
net 2.1.1.0 255.255.255.0 a 0
neigh 2.1.1.2 int outside (this is the outside IP of ASA1)
on R2
router ospf 10
net 20.1.1.1 0.0.0.0 a 0 (loopback IP)
net 4.1.1.1 0.0.0.0 a 0
thanks
kirti.
One more question, are R1 and R2 supposed to be able to talk OSPF or only ASA1 and ASA2?
i have enabled ospf on R1 and R2, so that the respective loopbacks on these routers are advertised; and thus i can send traffic from one loopback to another over the IPSEC tunnel.
hence i am running ospf on routers as well as asa.
thanks
kirti.
I see your loopback, but I don't see the interface you share with firewall on the inside.
In order to get this OSPF traffic accross the tunnel you need your router to be connected to the firewall on the inside interface in some sort of fashion.
hi i am already running opsf between the asa inside and the inside router and the loopback is on the inside router. on the asa i am receiving the loopback route via ospf.
the problem is the ospf running on the outside of the asa . i am not able ot establish ospf neighbourship between the 2 asa outside.
the ipsec tunnel is up and running.
regards
kirti
can somebody please help me with this issue.
waiting for reply.
thanks
kirti.
has anybody been able to implement ospf over ipsec vpn tunnel ?
please let me know the configuration.
regards
kirti.
438
