Unsure of how exactly an ASA inspects traffic
I am running a virtual ASA setup in GNS3. Using a loopback interface, I have ASDM running on my laptop that is connecting into my ASA firewall.
I am trying to ping from 192.168.1.1 (dhcp assigned to PC1) in the "inside" zone, to 192.168.2.50 (server 2 in "dmz" zone - security level 50).
The topology is as follows (I blocked out the made-up public range I'm using so as not to involk a real-life user somewhere - but that shouldn't matter in this scenario):
I have left all of the access rules as default:
When I ping (the PCs are really VPCS machines) I can see that the ping gets through from "inside" to "dmz", but not BACK. I understand that going from security level 50 to 100 is not allowed - however I thought that the firewall would INSPECT the traffic and make sure that return traffic would be allowed if it was initiated from the "inside" zone.
I'm not sure I'm reading these logs correctly. I can provide CLI output of the firewall if requested. I fairly sure this is something fundamental that I'm misunderstanding.
Can any help explain why my ping is failing? Thanks in advance
Jouni Forss
Are you sure you have enable ICMP Inspection?
This is NOT enabled by default on the Cisco firewalls
You should add something like (if you are using the default inspections/configurations)
policy-map global_policy
class inspection_default
  inspect icmp
  inspect icmp error
Alternative is to directly insert the old format commands that will apply the same configurations
fixup protocol icmp
fixup protocol icmp error
- Jouni
Unfortunately that didn't work. I have had to explicitly configure access rules allowing ICMP and DNS through:
I have literally only just started my journey into firewalls and I wanted to get this lab up and running as a starting point.
Based on what I learned in CCNA Security your suggestion seems to be correct. I'm sure I'm just applying it incorrectly because of my lack of understanding at this point.
Once I learn more and figure it out, I will come back and update this thread.
Well there shouldnt be many things that cant prevent ICMP from working.
Maybe you can share you current configuration in CLI format for us to go through.
- Jouni
