Upgrade ASA Failover From 7.2 to 8.2
Hi All,
Has anyone upgraded the ASA Failover pair From 7.2 to 8.2 ?
Does it incurs any downtime during the operation or its transparent for all the connections passing through.
I have read many documents which says that you can go from 7.2 to 8.2 directly, and i was able to upgrade stanalone firewalls without any issues.
But for failover, will failover work if one ASA in on 7.2 and other one on 8.2, or an intermediate upgrade is required.
Request help in this topic.
Guneet
  • Firewalling
1 ACCEPTED SOLUTION
Re: Upgrade ASA Failover From 7.2 to 8.2
This is possible in 7.2 to 8.2 and i have done upgradation in one of the main Telecom Company in India and I am 100% sure about that.
The two units in a failover configuration should have the same major (first number) and minor (second number) software version. However, you do not need to maintain version parity on the units during the upgrade process; you can have different versions on the software running on each unit and still maintain failover support. To ensure long-term compatibility and stability, we recommend upgrading both units to the same version as soon as possible.
I wish you to have a gr8 success ..
Karuppu
Find the method of IOS upgrade method in failover pair
1. copy tftp flash on primary ASA
2. shut down primary ASA (NOT reload)
3. Secondary is active now (Do a 'show failover' to confirm that)
4. copy tftp flash on secondary
5. shut down secondary (NOT reload)
6. boot up primary (and it will become active with new software)
7. Wait 3 to 5 mins->Do a 'show version' and 'show failover' on primary to confirm
8. boot up secondary (and it will become standby with new software)
for more info, just have a look into the below URL
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/mswlicfg.html
Karuppu
But can this be done without any downtime ?
Guneet Singh Gulati
Yes.IOS upgradation with zero downtime is possible.
1.copy tftp flash on primary ASA and set the boot system
2.copy tftp flash on secondary and set the boot system
2.activefw# failover reload-standby
When the standby unit has finished reloading, and is in the Standby Ready state, force the active unit to fail over to the standby unit by entering the following command on the active unit.Use the show failover command to verify that the standby unit is in the Standby Ready state.
4.activefw# no failover active
  Reload the former active unit (now the new standby unit) by entering the following command:
5.newstandbyfw# reload
When the new standby unit has finished reloading, and is in the Standby Ready state, return the original active unit to active status by entering the following command:
6.newstandby# failover active
Karuppu
Again come back to my original Q
when you give the below command, and the standby firewall loads with V 8.2 whereas primary is still in 7.2, will failover work between them having difference in versions ?
I am just looking for a complete solution, as i have critical firewall systems which i am planning to upgrade from 7.2 to 8.2  and if possible i would like to avoid a downtime.
Thanks in advance for help!!
Guneet Singh Gulati
Karuppu
Hi Karuppu
Thanks for the info, i will be upgrading it over the weekends.
Thanks and Regards,
Guneet Singh Gulati
Thats gr8,
Once you got the success in this IOS upgradation, just post the results in this forum.
It will bit helpful to other folks....
Karuppu
Yeah it works i faced no issues upgrading 7.2.3  to 8.2.2 ...thanks kauruppu
Guneet
3386
