Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Upgrade firmware on ASA?
I am familiar with upgrading firmware on Cisco routers but I am trying to update the firmware on an ASA - I downloaded the firmware and have it on the flash of the device but I don't see a line in the running config that calls out the image at boot like a router does - am I missing something or does it just boot from only a single image in flash? I see a line in the config that calls out the asdm image but nothing for the other.
1 ACCEPTED SOLUTION
Re: Upgrade firmware on ASA?
make sure you have the image - disk0
asa#dir
Directory of disk0:/
82 -rwx 6851212 05:22:16 Dec 11 2007 asdm-603.bin
83 -rwx 398305 09:02:36 Apr 19 2007 sslclient-win-1.1.0.154.pkg
2 drwx 4096 05:27:40 Dec 11 2007 log
85 -rwx 14635008 05:17:54 Dec 11 2007 asa803-k8.bin
86 drwx 4096 22:42:02 Apr 05 2008 sdesktop
6 drwx 4096 05:28:02 Dec 11 2007 crypto_archive
87 -rwx 545757 08:02:48 Jan 04 2008 rdp-plugin.jar
88 -rwx 2206269 08:03:34 Jan 04 2008 sslclient-win-1.1.4.177-anyconnect.pkg
89 -rwx 418765 21:55:44 Mar 21 2008 sslclient-win-1.1.4.179.pkg
90 -rwx 4740699 22:38:56 Apr 05 2008 securedesktop_asa-3.3.0.118-k9.pkg
Take notes of your currect boot variable statement
asaw# show run | inc boot
boot system disk0:/asa803-k8.bin
issue new boot statement
asa(config)# boot system disk0:/newimage.bin
also you need to tell asa which asdm image will be using, I assume you have downladed asdm image as well based on asa code.
Take notes of yur currend asdm statement
asa# show run | inc asdm
logging asdm informational
asdm image disk0:/asdm-603.bin
issue new asdm statement
asa(config)#asdm image disk0:/new_asdm_image.bin
here is some instructions on upgrading process examples.
http://www.cisco.com/en/US/docs/security/asa/asa80/release/notes/arn803n.html
asa#dir
Thanks, that helped, there did not appear to be a boot line there before I put it in - sh run with the boot option didn't show anything until I put the new line in.
Thanks for your update, once you confirm all statements are in placed and proper code confirmed reaload, if issues let us know we'll be here to help
thanks for rating
Rgds
Jorge
410
