Upgrading ASA from 8.2(5)46 to asa847-k8.bin
Hi Everyone,
I need to upgrade ASA  from 8.2(5)46 to asa847-k8.bin .
This ASA is used for Remote access VPN.
Need to know what steps i should take in order for this upgrade
Except Natting is there anything else that will change in the running config of device?
Current NAT i have is
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) 10.0.0.0 10.0.0.0 netmask 255.0.0.0
static (inside,outside) 172.16.0.0 172.16.0.0 netmask 255.255.255.0
Also ASDM need to upgrade to asdm-715-100.bin right?
MAhesh
Need to confirm is it safe to upgrade directly to asa847-k8.bin?
Is asa847-k8.bin stable version without any bugs?
2 ACCEPTED SOLUTIONS
VIP Green
"nat (inside) 0 access-list
"nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0"
This NAT will look like the following:
object network ALL_NETWORKS
  subnet 0.0.0.0 0.0.0.0
  nat (inside,outside) dynamic interface
Is there any reason you have these natting to themselves? in any case,  these will look like the following:
object network LAN1
  subnet 10.0.0.0 255.0.0.0
nat (inside,outside) source static LAN1 LAN1 destination static LAN1 LAN1
object network LAN2
  subnet 172.16.0.0 255.255.255.0
nat (inside,outside) source static LAN2 LAN2 destination static LAN2 LAN2
This link shows a good comparison between pre 8.3 and post 8.3 NAT configurations.
https://supportforums.cisco.com/document/33921/asa-pre-83-83-nat-configuration-examples
Please remember to rate and select a correct answer
VIP Green
"Also need to confirm if we
"Also need to confirm if we are using ALL_NETWORKS anywhere in NAT or not?"
From what you posted you have a NAT statement for the ALL_NETWORKS.  If this is in use depends on the location of the NAT statement in relation to the obj_any NAT statement.
object network obj_any
Are the same thing.  You only need one of these. So yes, you can delete one of them.  Be sure to do this in a service window as you will need to clear xlate and test to make sure everything is working correctly.
Please remember to select a correct answer and rate
VIP Green
There is a memory upgrade
There is a memory upgrade requirement also when upgrading to 8.3 and higher and depending on which model ASA you have the memory requirement differs.  Please refer to the following link for the requirements:
http://www.cisco.com/c/en/us/products/collateral/security/asa-5500-series-next-generation-firewalls/product_bulletin_c25-586414.html
Yes it is possible to upgrade directly to 8.4.  As for known bugs/caveats please refer to the 8.4 release notes:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa84/release/notes/asarn84.html#pgfId-404945
Other than the NAT there is a change to the way access lists work.  Instead of defining the NATed IP, now you need to define the real IP in the ACL.  So if you have NATed a server (10.10.10.10) to the ASA interface (1.1.1.1) then in the ACL that allows http traffic in on the outside interface you would define the 10.10.10.10 address and not the 1.1.1.1 address.
Yes, you will also need to upgrade the ASDM.
The following document describes some migration tasks that you may need to take into consideration.  worth having a read through it:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa83/upgrading/migrating.html
 i will go through the above
i will go through the above links and if any questions will ask you.
For current NAT
What would be new NAT in 8.4?
IF you can help me with this it will be much appreciated.
Mahesh
VIP Green
object network LAN1
object network LAN2
 Hi Marius, I did upgrade
Hi Marius,
I did upgrade today here is default config below that came after upgrade to 8.4
object network obj-10.0.0.0
object network obj-172.16.0.0
object-group network VPN_Access
 description VPN Access Subnets
 network-object 172.31.98.0 255.255.255.0
 network-object 172.31.92.0 255.255.252.0
access-list inside_access_in extended permit ip any object-group VPN_Access
access-list inside_access_in extended deny ip any any
access-list outside_access_in extended deny ip any any
access-list inside_nat0_outbound extended permit ip any object-group VPN_Access
access-list vpn_filter1 extended permit ip 172.31.98.0 255.255.255.0 172.16.7.0 255.255.255.0
access-list vpn_filter1 extended permit ip 172.31.98.0 255.255.255.0 172.16.3.0 255.255.255.0
nat (inside,outside) source static any any destination static VPN_Access VPN_Access no-proxy-arp route-lookup
 nat (inside,outside) static 10.0.0.0
 nat (inside,outside) static 172.16.0.0
Need to know if i did not done any changes to this then VPN should have work ok?
Then i apply the config below as you said
sh run nat
nat (inside,outside) source static any any destination static VPN_Access VPN_Acc                                          ess no-proxy-arp route-lookup
object network LAN1
object network LAN2
if not is it ok to delete ALL_Networks?
Best regards
MAhesh
VIP Green
Hi Mahesh,Sorry for late
Hi Mahesh,
Sorry for late reply as I have been away for a few weeks.
Do you require further assistance with this issue?
Pease remember to select a correct answer and rate
 Hi MArius, IF you can answer
Hi MArius,
IF you can answer my last question that will be much appreciated.
MAhesh
VIP Green
 Many thanks Marius Regards
Many thanks Marius
MAhesh
1067
