Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Urgent Pls Help - Debug Ethernet Interface on ASA
Hi, is there command to debug an Interface on an ASA5510 (7.2) ?
We are experiencing intermittent disconnections on the outside ASA interface which is connected to our ISP's 1841 router.
This is bringing down our remote VPN L2L connections
I have switched the interface to 100mb Full Duplex from auto to match the setting on the 1841 and I'm using a crossover but the issue still occurs with this error in the logs
"Line protocol on Interface Ethernet0/0, changed state to down"
The Interface and VPN then comes back up straight away but all RDP sessions running over our links are disconnected
Chris
Re: Urgent Pls Help - Debug Ethernet Interface on ASA
Start with a " show interface " command and look for error codes.
Here is also a good guide for troubleshooting this kind of issues.
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/intrface.html
Check that you have the same interface duplex and speed settings on both ends (100MB Full Duplex).
sincerely
Patrick
Community Member
Thanks, here are the Interface stats, seems to be OK
Interface Ethernet0/0 "OUTSIDE", is up, line protocol is up
Hardware is i82546GB rev03, BW 1000 Mbps
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
MAC address xxxxxxxxxxx, MTU 1500
IP address x.x.x.x, subnet mask 255.255.255.240
6850202 packets input, 5812329681 bytes, 0 no buffer
Received 4410 broadcasts, 0 runts, 0 giants
3 input errors, 3 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 L2 decode drops
6628378 packets output, 4889643034 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max packets): hardware (2/21) software (0/0)
output queue (curr/max packets): hardware (0/5) software (0/0)
Traffic Statistics for "OUTSIDE":
6850193 packets input, 5679324994 bytes
6628383 packets output, 4756896907 bytes
18704 packets dropped
1 minute input rate 31 pkts/sec, 3012 bytes/sec
1 minute output rate 39 pkts/sec, 34197 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 34 pkts/sec, 15824 bytes/sec
5 minute output rate 31 pkts/sec, 12659 bytes/sec
5 minute drop rate, 0 pkts/sec
Control Point Interface States:
Interface number is 1
Interface config status is active
Interface state is active
344
