Using Outside interface to connect to multiple machines inside
I have been working on a configuration for single IP address (on outside ) of ASA5505
I am trying to utilize the outside address 192.168.0.249 to PAT/NAPT to 10 inside machines
192.168.0.204:2180 ->192.168.111.10:21379
192.168.0.204:2181 ->192.168.111.11:21379
192.168.0.204:2182 ->192.168.111.12:21379
192.168.0.204:2183 ->192.168.111.13:21379
192.168.0.204:2184 ->192.168.111.14:21379
192.168.0.204:2185 ->192.168.111.15:21379
192.168.0.204:2186 ->192.168.111.16:21379
192.168.0.204:2187 ->192.168.111.17:21379
192.168.0.204:2188 ->192.168.111.18:21379
192.168.0.204:2189 ->192.168.111.19:21379
192.168.0.204:2190 ->192.168.111.20:21379
I have createdd acces-list
access-list outside_access_in extended permit tcp any host 192.168.111.10 eq 21380
access-list outside_access_in extended permit tcp any host 192.168.111.11 eq 21381
access-list outside_access_in extended permit tcp any host 192.168.111.12 eq 21382
access-list outside_access_in extended permit tcp any host 192.168.111.13 eq 21383
access-list outside_access_in extended permit tcp any host 192.168.111.14 eq 21384
access-list outside_access_in extended permit tcp any host 192.168.111.15 eq 21385
access-list outside_access_in extended permit tcp any host 192.168.111.16 eq 21386
access-list outside_access_in extended permit tcp any host 192.168.111.17 eq 21387
access-list outside_access_in extended permit tcp any host 192.168.111.18 eq 21388
object network ispec10
nat (inside,outside) static interface service tcp 21380 21379
object network ispec11
nat (inside,outside) static interface service tcp 21381 21379
object network ispec12
nat (inside,outside) static interface service tcp 21382 21379
object network ispec13
nat (inside,outside) static interface service tcp 21383 21379
object network ispec14
nat (inside,outside) static interface service tcp 21384 21379
object network ispec15
nat (inside,outside) static interface service tcp 21385 21379
object network ispec16
nat (inside,outside) static interface service tcp 21386 21379
object network ispec17
nat (inside,outside) static interface service tcp 21387 21379
object network ispec18
nat (inside,outside) static interface service tcp 21388 21379
object network ispec19
nat (inside,outside) static interface service tcp 21389 21379
object network ispec20
nat (inside,outside) static interface service tcp 21390 21379
What I am not sure of (actually that could be considered all encompassing) is the mapped services/real services
Any constructive comments assistance?
2 ACCEPTED SOLUTIONS
Your configuration is close, but you should swap the real and mapped ports. For example:
   nat (inside,outside) static interface service tcp 21379 21380
You can confirm this with the packet-tracer output:
packet-tracer in outside tcp 1.2.3.4 12345 192.168.0.204 21380
When you run that command, you should see that the IP of the server is untranslated from 192.168.0.204:21380 to 192.168.111.10:21379
Hope that helps.
-Mike
tgnovak-
I'm not sure why your reply states as such. The script above will work. I built out an environment (which is now production), which is exactly what your asking. If you look at the 'sh xlate' output above, it clearly show PAT from a single outside IP to 4 internal IP's. What I posted is indeed your solution. Thanks.
Hope that helps.
-Mike
Thanks for the response. That reaffirms my later findings
I made those changes and tested with packet-trace.  It was just late to repost to supportforum
Sorry for my lack of followup
Thanks Once again
-Thomas
Hi-
What exactly are you trying to accomplish with this solution. I'm assuming your trying to load balance here. Please see the script below, as should solve your problem. Also below that you will find the 'sh xlate' output from my test unit. I only did 4 hosts, so you will have to do the rest, but let me know how this works out. Thanks.
!---start
!-below is the ACL bound to the outside 'public' interface
access-list outside-to-inside extended permit tcp any host 192.168.0.204 eq 2180
access-list outside-to-inside extended permit tcp any host 192.168.0.204 eq 2181
access-list outside-to-inside extended permit tcp any host 192.168.0.204 eq 2182
access-list outside-to-inside extended permit tcp any host 192.168.0.204 eq 2183
!-ACL that will be referenced by the static PAT statements
access-list pat-acl-1a extended permit tcp host 192.168.111.10 eq 21379 any
access-list pat-acl-1b extended permit tcp host 192.168.111.11 eq 21379 any
access-list pat-acl-1c extended permit tcp host 192.168.111.12 eq 21379 any
access-list pat-acl-1d extended permit tcp host 192.168.111.13 eq 21379 any
!-below are the static PAT statements referencing the above ACL
static (inside,outside) tcp interface 2180 access-list pat-acl-1a
static (inside,outside) tcp interface 2181 access-list pat-acl-1b
static (inside,outside) tcp interface 2182 access-list pat-acl-1c
static (inside,outside) tcp interface 2183 access-list pat-acl-1d
!---end
!---output of translation table after applied (ie. show xlate)
ciscoasa(config)# sh xlate
4 in use, 4 most used
PAT Global 192.168.0.204(2180) Local 192.168.111.10(21379)
PAT Global 192.168.0.204(2181) Local 192.168.111.11(21379)
PAT Global 192.168.0.204(2182) Local 192.168.111.12(21379)
PAT Global 192.168.0.204(2183) Local 192.168.111.13(21379)
ciscoasa(config)#
Jean
It was not load balancing.
Customer has 11 internal machine that they collect data from and restricts me to one external address.
They use the OPC standard (DCOM) for communication.
There is a OPC tunnel deployed to transit the firewall (uses port 21379 on internal machines)
The requirement is to use only one external IP address (outside interface) to inside machines .
-Thomas
tgnovak-
1461
