Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Using Static NAT for network and host
Is it possible to use a static NAT for a network and then a different one for a host within that network.
Example:
static (inside,outside) 10.10.10.0 10.10.10.0 netmask 255.255.255.0
<---so that all 10.10.10.0 address are seen on outside as themselves---->
static (inside,outside) 10.10.10.5 11.11.11.5 netmask 255.255.255.255
<---so that 10.10.10.5 host is NAT'ed to different address--->
1 ACCEPTED SOLUTION
Red
Hi Rod,
Yes it is very much possible, the more specific one will take the precedence over the other static nat for the network,  , to verify it you can also run a packet tracer for it.
Packet-tracer input outside tcp 4.2.2.2 23456 11.11.11.5 80 detailed
and your static nat is not correct, it shoudl be:
static (inside,outside)  11.11.11.5 10.10.10.5 netmask 255.255.255.255
Varun
Thanks, Varun Rao Security Team, Cisco TAC
Red
Hi Rod,
Varun
Community Member
Thanks for the help!
227
